little power
Old Feb 19, 2012 | 01:13 PM
alexisvfd's Avatar
alexisvfd
little power
i have a 04 6.0 and i just changed 2 injectors lastweek and has ran perfect till lastnight i was going tdown the road and a pop under the hood and i lost probably 70% of my power..if i go up hill it just looses speed it will stay at a steady 45 to 50 on flat roads but has no get up at all.. any ideas
Old Feb 19, 2012 | 01:21 PM
Ian123's Avatar
Ian123
Did you pop the hood and look? You probably blew off an intercooler boot
Old Feb 19, 2012 | 01:22 PM
alexisvfd's Avatar
alexisvfd
i have and the conectors are all on there..its not missing any it runs fine just no power if that makes any since
BLADE35's Avatar
BLADE35
X2 here as well
Old Feb 19, 2012 | 01:32 PM
alexisvfd's Avatar
alexisvfd
its like its not getting all the air it needs
Old Feb 19, 2012 | 01:33 PM
run6.0run's Avatar
run6.0run
Or maybe it split out on the bottom.
Old Feb 19, 2012 | 01:35 PM
alexisvfd's Avatar
alexisvfd
what you mean
Old Feb 19, 2012 | 01:37 PM
run6.0run's Avatar
run6.0run
I mean, maybe the blue cac connector that is attached to the turbo has a split in it. Either way, chances are that you have a plumbing issue. I should be fairly easy to find with that big of a power loss.
Old Feb 19, 2012 | 01:38 PM
run6.0run's Avatar
run6.0run
Old Feb 19, 2012 | 01:39 PM
run6.0run's Avatar
run6.0run
Freakin mobile,,,,, sorry 4 the dp
Old Feb 19, 2012 | 01:41 PM
alexisvfd's Avatar
alexisvfd
yea i thought it would be easy to but there is no leaks no where and that connector is fine..idk it has really threw me off..
Old Feb 19, 2012 | 03:10 PM
BLADE35's Avatar
BLADE35
So your saying ALL 4 CAC Boots are good Clamps OK as well
Do you have the PLastic CAC Tube on drivers side coming from the cooler to intake manafold sometimes those split if there Both Metal this is not the issue
Old Feb 19, 2012 | 06:21 PM
alexisvfd's Avatar
alexisvfd
right all the clamps are tight and leak free
Old Feb 19, 2012 | 06:40 PM
zhilton's Avatar
zhilton
I thought that was an '05 and later thing? The plastic cold side tube that is.
Old Feb 20, 2012 | 07:39 AM
bonnydune's Avatar
bonnydune
My 04 has a plastic cold side CAC tube. I have ben fighting the same thing on my truck now for a few weeks. Take a look at my thread for some more ideas. (My turbo is now on my bench)
