OIL TEMP GAUGE NEEDED??
Old 02-19-2012, 08:15 AM
lee_faust2008's Avatar
lee_faust2008
lee_faust2008 is offline
i was just wondering if a oil temp gauge is needed??
mods to truck
air intake
4" turbo back exhaust
SCT programmer
should i be worried about monitoring my oil temp?
the reason i ask is that im going to install a 4 gauge pillar and im trying to decide on what gauges to install??
thinking of.....
100psi fuel pressure gauge
1500 EGT gauge
tans temp guage
and a boost psi gauge
hows does that set up sound?? any suggestions?
Old 02-19-2012, 08:38 AM
texans's Avatar
texans
texans is offline
oil temp is one of the most important (if not the most) gauge to have with a 6.0. If it were me I would do away with the turbo boost gauge and get an oil temp instead. It is really important to keep a close eye on the EOT/ECT deltas. Since you have a 06 you should have the factory boost gauge in the cluster. It actually is one of the only factory gauges that works pretty good.
Old 02-19-2012, 09:23 AM
lee_faust2008
ok cool thanks for the tip..... what about the other gauges?
Old 02-19-2012, 09:27 AM
texans's Avatar
texans
texans is offline
I would also replace the trans temp gauge with a PYRO. Although the stock trans temp is pretty much useless, at leat there is one. Being a tuned truck, I would want to see EGT's along with FP, EOT, ECT.
Old 02-19-2012, 09:29 AM
lee_faust2008
isnt the pyro and EGT gauge the same??
Old 02-19-2012, 09:39 AM
lee_faust2008
heres exactly what im looking at....
99-07 Ford Super Duty PowerStroke Quad Custom Gauge Package
gauges installed:
100PSI Fuel Pressure Gauge
Transmission Temperature Gauge
1500° Pyrometer EGT Gauge
oil temp gauge
let me know if i should switch out gauges to another more important gauge that im not thinking about right now
Old 02-19-2012, 09:49 AM
texans's Avatar
texans
texans is offline
Oh yes, Pyro and EGT are the same. I guess I miss ready the original post.
I would still do away with the trans temp (if you were only going with 4), and replace it with ECT. The reason is the same as EOT. You really want to keep an eye on the deltas between ECT and EOT. Very, Very important with the 6.0
So with a 4 gauge setup here is what I would recomend for you
ECT
EOT
EGT
FP
Old 02-19-2012, 10:05 AM
lee_faust2008
ok im pretty new to diesels so could you tell me exactly what is a ECT?
Old 02-19-2012, 10:06 AM
lee_faust2008
and EOT?........
Old 02-19-2012, 10:14 AM
texans's Avatar
texans
texans is offline
ECT = engine coolant temp
EOT = engine oil temp
Old 02-19-2012, 10:17 AM
lee_faust2008
do you mean the water temp gauge? i know its prolly a dumb question but i dont see a engine coolant gauge just a water temp gauge
Old 02-19-2012, 10:19 AM
BLADE35's Avatar
BLADE35
BLADE35 is online now
ECT= engine coolant temp
EOT= engine Oil Temp
You should consider a SGII its digital and then install EGT,FuelPrss,and whatever else you want on the Pillair
But the SGII is going to get a TON of gauges from the OBDII port
Old 02-19-2012, 10:21 AM
Ginther's Avatar
Ginther
Ginther is offline
Or you could get one of these and have several gauges in one for a lot less money.
ScanGaugeII
ScanGaugeII
Old 02-19-2012, 10:22 AM
lee_faust2008
are the engine coolant temp gauge and water temp gauge the same thing??
Old 02-19-2012, 10:37 AM
texans's Avatar
texans
texans is offline
yes same thing
Quick Reply: OIL TEMP GAUGE NEEDED??
