351w 5.8 mods???
Old 02-18-2012, 09:40 PM
Shwan_89HD's Avatar
Shwan_89HD
Shwan_89HD is offline
351w 5.8 mods???
I have a 89 f250 351w with a C6 trans (bone stock), what are some mods that are more less inexpensive and get gain in power? ive looked into already some CAIs and longtube headers, anything else?
Old 02-19-2012, 01:44 PM
1990f150kid's Avatar
1990f150kid
1990f150kid is offline
cams is the biggest thing, injectors, k$n cold air intake, cleaning out your motor, egr delete, change all fluids, personally i would go with royal purple 10e-40 motor oil but thats a personal preference there
Old 02-19-2012, 03:28 PM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
6liter tuneup first then Cam, heads and exhaust would be up there
CAI- only thing you'll see there is a different sound, the factory intake is plenty( I have an eBay CAI lovd the sound but no performance gains)
Egr delete- it has been said that if the egr is workin properly then it helps MPG and removing it won't change performance it would raise the operating temperature.
10w40 oil- depends on. Where you live. If its a cold environment
it's too thick and you'll have problems when the temp drops.
Other suggestions.-
Remove the air pump system. Use idler pully in its place By removing the pump it's one less thing for the motor to turn hence freeing up a bit of power
E-fan - remove the stock clutch fan and install electric fans. The fan draws alot of power when it kicks in so removing that will free up more Hp
Old 02-19-2012, 07:24 PM
1990f150kid
what exactly does the air pump system do anyways? and i said 10w40 cause where i live its murderously hot
Old 02-19-2012, 07:50 PM
blkF250HD's Avatar
blkF250HD
blkF250HD is offline
The air pump introduces air into the exhaust stream to help burn off any unburnt fuel. On some vehicles it supplies the catalyst with the oxygen it needs to function.
First do all your maintenance work. Fluids, filters, ignition components. Then go with a free flowing exhaust and headers. Finally a SD friendly cam will net you some gains. Rear end ratio and tire size play a huge role in "seat of the pants" feel.
Old 02-20-2012, 06:39 PM
Shwan_89HD's Avatar
Shwan_89HD
could you link me to a good performance cam?
Old 02-20-2012, 08:06 PM
86F150302's Avatar
86F150302
86F150302 is offline
cams is the biggest thing, injectors, k$n cold air intake, cleaning out your motor, egr delete, change all fluids, personally i would goith royal purple 10e-40 motor oil but thats a personal preference there
What!
First do a 6 liter tune up
Bump the timing up(free power)
LT headers with a nice exhaust setup.
E fans
Under drive pulleys
1.7 roller rockers
GT40 heads
Search will turn up a ton of info on making more power.
86f250hd
09-14-2014 12:47 PM
Quigles4
11-19-2012 09:06 AM
Rbalkema
13
06-25-2012 07:51 PM
streetlude95
09-01-2011 05:20 AM
Quick Reply: 351w 5.8 mods???
