Won't go to cold...
Old Feb 18, 2012 | 11:27 AM
Bundy34's Avatar
Bundy34
Won't go to cold...
Greeting all,
I have a 1997 Expedition EB and am having a problem with the temperature selector.
It will go to hot without issue, but when turned to cold, it will not change temp. I can hear the blend door moving and the twist switch on the dash is not cracked.
If I turn off the air, move the temp control back and forth a couple of times before leaving it on cold, and turn it on low, it will then blow cold and seem to work fine. Until I turn it back to heat, where it gets stuck again.
I read several threads on this and have seen others having the same symptoms, but none are updated with what their particular problem was, at least in regards to getting it to go cold with turning off the air.
Any advise would be greatly appreciated.
Old Feb 18, 2012 | 12:57 PM
alloro's Avatar
alloro
Sounds like the infamous broken blend door issue. There are many threads in this forum relating to blend doors. Searching for and reading those might getting you going in the right direction.
Ryland
1997 - 2003 F150
35
Jun 26, 2015 02:54 PM
DWL
Jan 16, 2006 04:43 PM
milmo1
1983 - 2012 Ranger & B-Series
Aug 1, 2004 12:51 AM
scabbard
May 7, 2004 09:36 PM
