I need some help!
I want to add a second battery to my truck to power my fog lights, offroad lights, and my sound system. I have seen mnay guys put their 2nd battery in their bed, but where to I drill the hole to get the wires trough, or is their a hole already there( i couldn't find one). Any information on this subject would be greatly appricated. Thanks in advance.
-Matt
You could also just wire them directly together, just to have more battery capacity for everything. Either way, make sure you use very heavy duty wire, run it through wireloom underneath the truck, and make sure that you use good grommets anywhere the wire goes through metal so it doesn't short out. People will also probably tell you to use 2 new identical batteries. I didn't find that to be a problem when I used a battery isolator, but might be a problem if you wire them directly together. If you wire them together, you also need to make sure that you wire them in parallel (positive to positive, negative to negative). If you wired them in series, you'd have 24 volts. Sorry if any of this is obvious to you, just trying to help.
You may even be able to get the second battery underneath the bed. I'm not positive, but I've looked around and it seems like you could fit one up there somewhere out of the way.
Someday when I have the money, I'll probably put in a battery isolator and a deep cycle battery mounted under the bed. I did this in my VW van and was very happy with it. Sorry for another long post...
Brian J Wilson
I plan to place it in a isolated container in the top left(towards the window) of the bed, it will be part of a box that i'm making. Thanks for all the info, i appricate it. I'll let you know how it goes.
-Matt
vs the stock 90? amp unit.
If you need 2 batteries you might need a higher amp alternator to keep them charged while your running all that stuff.
Rand
