6.2L mpg update?
#301
#302
Hello all, I am new to the site and to having a truck and a Ford. I love this site. I wish I found it before my purchase, but I am happy with my purchase so far. I bought a 2016 F250 4X4 Crew Cab Lariat with the standard gears. I knew the MPG was not going to be good when I bought it. I bought my truck to pull a travel trailer. I was told to buy the bigger truck so if I upgrade to a fifth wheel, I don't have to buy a new truck. I have found a lot of things that change my MPG. First thing was the truck had the hub locked when I bought it. Like I said I am new to trucks. I put in a regular K&N air filter. Those two things helped. I bought a cover for the bed. I like the cover, but it reduced my MPG by .5 miles per gallon. I have played with the rear tire pressure and finding it also reduced .5 miles to the gallon. With no cover, tires aired to suggested levels, K&N air filter and the hubs in auto, I get about 14 MPG on an average (combination highway and city). Of course, keeping off the gas at lights helps. I am older and in a big truck now. No hurry to go anywhere fast.
#304
#305
#306
Just made my first road trip since right after I bought the truck. It has 3700 miles on it now. I averaged 17 mpg on the computer. Would have been around 18, but did a bunch of idling going into/out of a ballgame. Interested in checking against pencil and paper, but really computer has always been within .2. This trip is definitely better than my first, could not average 13 then, guess the motor is broke in + summer blend. It was @ a 200 miles trip.
Oh yeah, ccsb 4x4 3:73 245/70/r17
#307
Just made my first road trip since right after I bought the truck. It has 3700 miles on it now. I averaged 17 mpg on the computer. Would have been around 18, but did a bunch of idling going into/out of a ballgame. Interested in checking against pencil and paper, but really computer has always been within .2. This trip is definitely better than my first, guess the motor is broke in. It was @ a 200 miles trip.Attachment 148056
#309
That's great info. I have been testing myself and following everyone's mpg posts throughout the forum. It is becoming evident that the stock small tire do better than the large 34.2" stock tire trucks with 3.73. I run 33" tires and maybe with summer fuel can get 14 on a hwy tank. I am seeing that the 6.2 seems to do best on average with the stock 31.5" tires if equipped with the 3.73. If one is to run the largest 34.2" tires on the 20" wheels and opt for the 4.30 gears, the net rpms will be only 100 more. That is where I will be when my new truck gets here.
If you ever change out your tires to the larger size, I would be real interested in what you see in mpg decline.
I get almost 1mpg better locking out 6th on my truck when running on the hwy replicating my new truck with 4.30's(55mph). When I drive the same hwy in 6th I get worse mpgs(60mph). This is the best way I can compare my same truck as if it had the 4.30 gears.
#310
My dads regular cab with 4.30 gears and 245/70/r17 tires is already averaging 12.5 around town. It has less than 1k on the odometer and I still can't get that around town. I'm kicking myself in the butt so hard for not ordering a truck with 4.30's, mainly because I plan on going to 35's or 37's in the future. 6th gear will be useless with 3.73's hauling anything more than a load of balloons.
#311
The large notion of the 4.30 gears netting worse mpg's is simply not happening. With small tires and 70mph+ interstate driving may be the only scenario where the 4.30 does get worse.
#312
#313
#315
You get better mpgs running at 1780 rpms than you do at 1527 at least while towing. I have similar results it that my truck gets better mpgs when I make my commute locking out 6th gear and cruising around 1750 rpms than I do when I do the same run in 6th at 1500 rpms. I also have 33" tires and 3.73 gears.
