turbo bark?
Old Feb 16, 2012 | 11:56 PM
kupaa's Avatar
kupaa
turbo bark?
Why does my turbo bark or shutter? What will cause it? It does it on the shifts and when i let off the throttle when I'm on it.
Old Feb 17, 2012 | 12:22 AM
kawcrasher's Avatar
kawcrasher
It is from all the boost that suddenly has no place to go when you let off the throttle. It's normal and nothing to worry about.
Old Feb 17, 2012 | 01:08 AM
kupaa's Avatar
kupaa
but even with a 38R?
Old Feb 17, 2012 | 01:55 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Its called turbo stall. It happens when the pressures on either side of the turbo suddenly change when boost demand drops such as a shift or letting off the throttle.
Turbo Stall - F250 7.3 Powerstroke - YouTube
Old Feb 17, 2012 | 07:50 AM
mueckster's Avatar
mueckster
Mine does it with 38r and the larger 1.15 A/R exhaust housing also. It is less pronounced during normal driving and hardly noticable. Or, I've just become accustomed to it.
Old Feb 17, 2012 | 08:06 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I never noticed this with my TN BB turbo.
Old Feb 17, 2012 | 08:11 AM
mueckster's Avatar
mueckster
That's because you're special, Rick! Odd man out with your TN turbo.
Old Feb 17, 2012 | 08:21 AM
miller_feed
Do you mean? Old man with your BAD AZZ TN turbo.
Old Feb 17, 2012 | 08:56 AM
mueckster's Avatar
mueckster
That'll work, too!
Old Feb 17, 2012 | 09:08 AM
CSIPSD's Avatar
CSIPSD
Saying its nothing to worry about is a bit of a stretch.
It can snap the shaft, but its very rare.
There is not much you can do about it however.
Old Feb 17, 2012 | 11:07 AM
homesteader's Avatar
homesteader
That doesn't sound good on the turbo!
Old Feb 17, 2012 | 12:11 PM
kawcrasher's Avatar
kawcrasher
Therefore, it is nothing to worry about.
Old Feb 17, 2012 | 01:37 PM
kupaa's Avatar
kupaa
Yep it doesent sound good at all,it's like the boost is spinning the blades backwards. Is it hard on the blades and could it bend it or how about the bearings?
Old Feb 17, 2012 | 02:46 PM
CSIPSD's Avatar
CSIPSD
Old Feb 18, 2012 | 02:50 AM
homesteader
Chris was it doing it before ? If not,you should check your turbo!
