Towing Questions
Old Apr 23, 2003 | 09:19 PM
stealth1's Avatar
stealth1
Towing Questions
I'm new here so hello to everyone!! Well here it goes. I have a 1997 4dr 2wd explorer with a 4 liter sohc with a 3.55 rear end. I want to pull a 23' travel trailer. I pretty much know I need a tranny cooler and equalizer hitch to start. How much would I benifit from a power module and a k&n type air induction kit? Would a oil cooler help as well? Any help with a certain type or brand will be useful. Or any other mods that I could try to increase hp and torque. This is my wifes daily driver and I would like to keep it as reliable as possible but still tow my camper 5-8 times a year. Do they even make a power module for a explorer? If so do they make one that can be switched between economy and towing? Thanks again...
Old Apr 24, 2003 | 07:51 AM
SplashMan's Avatar
SplashMan
Towing Questions
Any or all of those options you listed will help with the towing, life of tranny and overall life of the X. The first things I would get would be... class three or IV hitch of course...
1. tranny cooler (www.sumittracing.com) bigger the better.
2. add-a-leafs/helper springs (www.jcwhitney.com)
3. K/N drop in or cone filter (most shops sell them)
4. switch over to synthetic oil (Mobil 1, Amasoil... etc.)
5. Aux oil filter/cooler (www.summitracing.com)
6. Weight distributing hitch
7. B&M shift kit (www.summitracing.com
8. Chip (www.explorerexpress.com)
There are not a lot of power aids for the SOHC out there. It is pretty beefy from the start and with good maintenance (yearly tranny fluid change), it should serve you well for 5-8 trips a year. I towed my 16' trailer and Bronco II (6,000lbs combined) with my '99 XLT 4x4 SOHC for a year and never had any problems. The hills will slow you down of course, but you will be surprised at the power.
Old Apr 24, 2003 | 06:14 PM
stealth1's Avatar
stealth1
Towing Questions
That's what I was looking for!!!! Thanks a thousand times...........
Old Apr 25, 2003 | 08:21 AM
BrianA's Avatar
BrianA
Towing Questions
Hey Stealth,
if you haven't already done so, I suggest you ask more questions in the "Towing" forum.
IMHO, a 23 ft travel trailer is gonna be a bit much for an Explorer.
You might wind up having the tail wagging the dog.
Not to sound like a know-it-all, but I'd do a bit more investigating before hitting the road. There are some pretty knowledgable folks in the "Towing" forum. Give it a look.
Oh, by the way, Welcome to FTE. I hope you enjoy it here as much as I do.
Thanks.
Old Apr 26, 2003 | 02:54 AM
ford_tr_man's Avatar
ford_tr_man
Towing Questions
i have towed my 25ft TT with both my explorers (94 4x4,97v8 awd) and they haddled it pretty well both are stock with tow pkg
Old Apr 26, 2003 | 07:06 AM
stealth1's Avatar
stealth1
Towing Questions
I just found the towing forum (stupid me didn't see it before) It has alot of useful info. Thanks again everyone!!!
