Sponsored by: Real Truck
Camper
Old Feb 16, 2012 | 04:36 PM
GeneLaw1's Avatar
GeneLaw1
Camper
Gentleman,
I want to take a trip with a camper. I do not own one, but I was considering renting one for the trip...any one ever done this? I definitely can not afford to buy one, lol...thanks for any info or tips!
Cheers,
Old Feb 16, 2012 | 06:24 PM
arto_wa's Avatar
arto_wa
Long time ago I rented Frontier 911 in Vancouver, to haul in 81 F250 SC; it worked out very good!
Are there rental campers in your area?
What kind of truck you have - 3/4 ton, 1 ton, single rear wheels, 4x4, engine & transmission etc.?
Your truck will need camper tie-downs.
How large/heavy camper are you planning to rent? Does your truck have electrical wiring connector for a camper lights and battery charging?
Does the truck have rear-view mirrors wide enough apart, to be used with a camper?
Etc. etc.
Old Feb 17, 2012 | 10:55 AM
GeneLaw1's Avatar
GeneLaw1
Etc. etc.
I have seen some RV retailers in my area (Atlanta, GA) that rent. The truck is '06 F250, guessing thats 3/4ton? Single rear wheels, 6.0 PSD, tranny is the stock one far as I know. Not really wanting to get one absolutely huge, enough for two people is fine. The last one I saw online was a 30 footer, but I wont need one that large. I have seen two wiring connections, one small one that I have used for the car hauler I have pulled, then a larger one that I am not sure what the use is for.
Old Feb 17, 2012 | 10:57 AM
powerstroke72's Avatar
powerstroke72
Gene, just a thought here but it couldn't hurt to post this in the Trailer Towing forum as well. There is a huge knowledge base there and most of those guys tow RVs a lot of the time. Here's the link:https://www.ford-trucks.com/forums/forum68/. Like I said....just a thought.
Old Feb 17, 2012 | 01:15 PM
mwsF250's Avatar
mwsF250
So it sounds like you're looking at renting a trailer?
When I hear "camper", I think the type that fits in bed.
A sub 30' bumper pull? That's a piece of cake for these trucks. My nephew has rented. Don't go for the cheapest - go for the best maintained. It sucks to discover the rental has issues - and RV's have a LOT of systems that can have issues!
Your truck will need a good class III or IV receiver and a trailer brake controller. If the trailer is a good one, you don't "need" weight distribution bars or sway control, but it sure makes towing effortless. If the renter offers a WD/sway control hitch option, definitely take it.
If not, keep all the heavy stuff in your truck in FRONT of the rear axle.
Old Feb 17, 2012 | 01:23 PM
arto_wa's Avatar
arto_wa
Sorry, looks like you were talking about travel trailers, my comment was about slide in pickup campers!
Old Mar 8, 2012 | 12:51 PM
GeneLaw1's Avatar
GeneLaw1
Originally Posted by powerstroke72
Gene, just a thought here but it couldn't hurt to post this in the Trailer Towing forum as well. There is a huge knowledge base there and most of those guys tow RVs a lot of the time. Here's the link:Towing, Trailers & 5th Wheels - Ford Truck Enthusiasts Forums. Like I said....just a thought.
Thank you very much! I did not realize there was a forum for it, I will go there...
Old Mar 8, 2012 | 12:52 PM
GeneLaw1's Avatar
GeneLaw1
Great information, thank you for correcting my use of the word camper.
Old Mar 8, 2012 | 01:41 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Probably the factory 4-pin and RV 7-pin connectors that most SDs should have. The 4-pin only does brake lights/turns signals and tail lights. The 7-pin adds brake signal, aux power wire and backup lights. You have everything you'll need inside the 7-pin, you just might have to buy an adapter to step down to the 6-pin commonly found on smaller RVs (or round 4, flat 5, whatever the trailer has on it)
http://howto.curtmfg.com/sitepro12.s...lugDiagram.jpg
Kevinm1980
Aug 27, 2018 01:56 PM
Anita's15
May 21, 2018 03:35 PM
poodlemaster187
May 10, 2017 05:46 PM
mswift
Sep 7, 2005 11:21 AM
godxofxemptiness
Jul 16, 2004 05:30 PM
