valve cover help
Old Feb 16, 2012 | 08:18 AM
nintey4f150's Avatar
nintey4f150
valve cover help
can i use an aftermarket tall valve cover on my efi 351w.. or do i have to get the truck valve covers?... im assuming i can buy tall baffled valve covers but i wanna make sure.. im wonderin gwhat ill have to do with the pcv and also the oil fill... im going to be running a trickflow r series intake with a spacer
Old Feb 16, 2012 | 09:48 AM
SCRebel's Avatar
SCRebel
I believe you cant run the tall valve covers because of the plenum. I believe most sites also specify EFI or Carb.
Old Feb 16, 2012 | 10:13 AM
rla2005's Avatar
rla2005
I think you will be fine running taller valve covers with that R-series intake:
The photo above is a Cleveland-headed 351W block running a Trickflow intake. Looks like plenty of room to me
Old Feb 16, 2012 | 10:41 AM
nintey4f150
like i said ill be running a spacer incase and already have a cowl hood so clearance isnt an issue... im just wonderin if ill have to re route the pcv valve.. and was also wondering about the oil fill
Old Feb 16, 2012 | 10:57 AM
rla2005's Avatar
rla2005
The PCV valve and "vent" are usually on opposite sides of the engine. The photo I posted shows the PCV on the driver's side front valve cover. If it were mine I would put it back in the factory location of the passenger side valve cover near the rear. The oil fill on the factory engine doubles as the "vent" location. There should be an extender piece for the cap and a nipple with a hose leading to the airbox to draw in fresh air.
You could use a vented fill cap if you are running a Speed Density system. If you are planning on running Mass Airflow (MAF) you need to run the "vent" hose to the air intake after the MAF meter. Otherwise you will have unmetered air running into the engine, it will cause problems.
Old Feb 16, 2012 | 11:14 AM
nintey4f150
yes the pcv will b on the passanger side and yes im running mass air.. is there a way to run a vent line to the driver side .. all the tall baffled valve covers only have a hole for the fill cap
Old Feb 16, 2012 | 12:25 PM
rla2005's Avatar
rla2005
Use the factory fill cap extender:
Old Feb 16, 2012 | 12:40 PM
nintey4f150
i know what you are talking about but those are stock height valve covers.. i need tall ones and if u search them all they have is a hole in the top of the cover for the oil cap
Old Feb 16, 2012 | 12:58 PM
SCRebel's Avatar
SCRebel
I totally missed that, Sorry
Old Feb 16, 2012 | 03:18 PM
rla2005's Avatar
rla2005
A quick Google search found this: Moroso : 68450
Note: Inside cover is pilot notched, making it easy to cut out openings for a PCV valve, breather or oil filler cap; includes grommets
Old Feb 18, 2012 | 10:38 PM
nintey4f150
ok so does anyone know if the ford racing efi truck valve covers would clear stud mounted 1.6 rockers?
andrew's64
Jan 18, 2016 02:54 PM
jerg_064
Mar 3, 2008 08:45 AM
AYoungblood
Jul 14, 2004 10:21 PM
karlsd
Oct 1, 2002 04:12 PM
