4x4 speed?
Old Feb 16, 2012 | 07:52 AM
j250hd's Avatar
j250hd
4x4 speed?
What's the highest (safest) speed our trucks can go in 4 high?
Old Feb 16, 2012 | 11:23 AM
Midwest Dually's Avatar
Midwest Dually
I tend to go no faster then 45-55 (mph). 45 mph on pavement with snow and ice conditions, and 55 on dirt roads with adverse conditions. I even think thats what the owners manual stated, but not sure!
I grew up driving the 70's F-series, and that was all a person would want to do in those things! LOL!
Old Feb 16, 2012 | 11:34 AM
fridgeddiesel's Avatar
fridgeddiesel
I once had mine going fully pegged 5th gear around 3200 rpm once in 4 wheel drive passing an enormous line of traffic in South Park. I would guess it was somewhere just over 100 mph but not sure as the speedometer doesn't go that high. That was the fastest my truck has ever gone and I don't think it has been over 80 mph since..
I have driven 60 mph on snow packed roads in 4 wheel drive all winter for the last 14 years. No problems. Going slow with sharp turns is harder on the 4X4 than driving straight down the highway.
Old Feb 16, 2012 | 01:58 PM
bad12jr's Avatar
bad12jr
Had mine to 73 at the drag strip. They just tend to pull like a front wheel drive car when they torque out of the hole.
Old Feb 16, 2012 | 03:28 PM
glovemeister's Avatar
glovemeister
Anything over 45-50 means one of two things, 1 you shouldn't be in 4x4 in the first place as the conditions are not bad enough, or 2 the weather is bad and you are driving like a jackwagon.
Old Feb 16, 2012 | 04:01 PM
fridgeddiesel
That may be the case in Oregon. In Colorado where it is very dry and not icy the roads can be snow packed for long periods of time up here in the mountains. Out here you typically drive 55-60 on snow pack. I sure wouldn't drive at those speeds in 2 wheel drive on snow pack. In 4 wheel drive you really don't notice the difference between snow packed roads and 2 wheel drive on dry roads. Just don't slam on the breaks.
In the summer months we only have 3 paved roads in our county which is larger than the state of Connecticut. A lot of my driving is on dirt roads that get mighty wash boarded from the logging trucks and RV's. Once again 4 wheel drive is a must or you just beat yourself up. Typical speed on most of the dirt roads is 45-55 mph.
You can drive in 4 wheel drive as fast as the conditions allow. There is no mechanical related top speed for using 4 wheel drive.
Old Feb 16, 2012 | 05:54 PM
glovemeister
That is the issue is conditions allow. Just because you can go that fast doesn't mean you should. In my county every year we get tons of wrecks about 15-20 simply because people from out of state think they have 4x4 and they can go as fast as they want to. Jeeps, Subarus, and jacked up trucks are nearly always in the ditch. Little cars are very rarely in the ditch unless one of these hits them.
Hell here two years ago we had a guy get decapitated because he was in 4x4 doing 60 in 4x4, came upon a slight corner and started to turn and he headed right across the center median. Semi coming the other way was all the way off the shoulder trying to avoid it and nearly flipped, when the toyota truck hit him. The crash broke the toyota bed mounts and the guy driver was instantly killed.
So just my humble advice from working EMS/fire, I don't like seeing dead people so take it easy even with 4x4.
Old Feb 16, 2012 | 06:40 PM
Midwest Dually
I second this! I try to not get on anyone about their driving style or preferences! However in every single driver's safety course I have had to go through including EVOC, the saying is; do not out drive what the conditions and vehicle are capable of. Increase distances of stopping and following, and slow down, plan more time for travel.
All it takes is just one time... Just once, even after 100,000 times of nothing happening!
Old Feb 16, 2012 | 10:14 PM
BuckHammer's Avatar
BuckHammer
...jackwagon.
I believe that you've hit your daily usage limit for the term jackwagon.
Old Feb 17, 2012 | 01:18 AM
glovemeister
I use that over on the arfcom too lol? I was rereading posts and remembered seeing me saying jackwagon like ten times lol. Guess I reached my weekly allotment.
Old Feb 17, 2012 | 07:17 AM
Ken_C's Avatar
Ken_C
^^^ what they said^^^ take your time. not worth wrecking the truck or worse.
I know that driving in a straight line is easier in 4X4 than it is to try to make a hard to the lock turn. using a restaurants drive through is almost impossible in 4x4 because of the hard u turn that most of them have. it scared the crap outta me the first time it happened. it tends to bind up if youre stopped then try to make that hard of a turn. I also read in the manual about max speed in 4x4 dont remember the number though.
Old Feb 17, 2012 | 09:27 PM
BuckHammer's Avatar
BuckHammer
Just thinking about making a hard turn on pavement in four wheel drive made me cringe.
Old Feb 17, 2012 | 10:04 PM
bad12jr's Avatar
bad12jr
Yea a whole lot of bad noises lol. Hard hairpins in 4wd are impossible almost.
Old Feb 17, 2012 | 10:33 PM
BuckHammer's Avatar
BuckHammer
Why would you want to try?
Old Feb 17, 2012 | 10:36 PM
bad12jr's Avatar
bad12jr
Had it in 4wd when it was snowing one night. Pulled in to get diesel and had forgotten what I had done and the awning covers the front of the building to the pumps.
It will scare the crap out of you.
