Is the Triton V10 truly a P.O.S for modding?
#31
Sorry, I was referring to aftermarket heads. The heads are heavily modified by an outstanding head guy,Titanium valves, retainers, etc... You can't make that kinda HP on a stock head or intake. It also has a sheet metal or aluminum intake that was custom made(Wilson Manifolds).
#32
#33
But who buys a full size truck with a v10 for fuel economy
#34
Nope. They are every bit as good an engine for modding as any Ford modular engine - and arguably better as they should always end up with about 25% more torque/hp than a V8 with identical tuning.
But they are NOT cheap or easy to mod for amateurs who need everything "bolt on". There are not many bolt on parts or "kits" available.
#35
#37
the barley 11 mark is in winter driving... keep an eye on my sig when it gets warmer i usally check my miles then update my sig quite often. in the summ the most i have ever got was 13.6 and i would say about 65% h-way and 35% city!
and i might be saving gas but the parts on here u can tell are HP parts. so its not like i did it all 4 the mpg it was for the MPH when i need it! lol
#38
V10 can't get to 700hp?
Maybe you should dump that boat anchor motor and get yourself a little 4 banger honda motor that CAN handle the power!
S2000 Dyno Vid STOCK BLOCK RECORD by Blevins Tuning - YouTube
#39
OK, difficult to mod, but not impossible.
We start with custom ground camshafts. Comp Cam has the blanks and will grind to your specs, plus the valve springs you'll need for the added lift.
http://www.compcams.com/Technical/Ca...2007/pdf/3.pdf
Sullivan Performance has some knowledge to tap. They can probably direct head porting efforts for maximum flow.
Sullivan Performance Products
As stated earlier, Whipple did make a 2V supercharger kit, but discontinued it. Might be worth it to scour eBay looking for these parts.
Whipple | eBay
Headers, you better get some, plus a free flowing cat and a performance muffler.
http://www.google.com/webhp?rlz=1C1C...5&ix=seb&ion=1
Not a Whipple, but here is a Paxton supercharger kit for a 1999-2001 V-10
Paxton 1999-2001 Ford V-10 Truck/SUV Supercharging System w/ NOVI 2000, Satin [PAX-1001911] - $4,013.00 : Powered By Ford - #1 Source for Mustang performance parts and Ford car or truck parts, When you want it done right and done well there is only o
Whipple | eBay
#41
#44
#45
2 liters are for drinking, not racing....
