CNG F 350 7.5 DRW
it may cost some money to refurbish that home compressor station, but keep in mind that you are compressing a highly flammable gas. if it leaks or fails, all that will be left of your home and family is a smoking hole in the ground.
We use electricity too, if there's a short in the wiring, your house can also burn down, so we should stop using electricity too ?
There are dangers to everything you do in life, it would get mighty dull if all we did was sit still and did nothing til we died..........................oh, wait! if we did that we could DIE !!!!!!
Natural gas for home heating, power generation and large city Bus fleets makes sense to me. Trying to do it in millions of cars just doesn't make much sense. It's simply just too hard to handle. At the industrial level the compressors have to be constantly maintained, serviced and worn parts replaced. The high PSI involved is very hard on the final stages of the pumps, and filling station problems with couplings are always damaged. LPG power to Industrial equipment is the perfect example. A business loads up a truck load of fuel tanks and deliveres them to Industrial users each shift. Very labor intensive. Industry is mostly converting over to rapid charging Electric vehicles. Go that way instead.
Nothing wrong with natural gas for home heating I'm 44 and have used gas heat all my life. The problem come when unsupervised amateurs try to compress it. That is what "can" make it dangerous
Natural gas has been used in homes for decades now, so I guess using your logic, we should all stop ?
Was reading today where a start up company can predict synthetic gasoline made from air will be cheaper than pump gasoline if someone will give em a wind generator for the electrical part.
I'm looking for oil and gasoline prices to come down dramatically when two things happen: The first thing that needs to take place is to vote Obama out of office, along with all his anti-oil minions. Second, the price you're now paying for oil is financing the oil drilling boom in the Bakken and Eagle-Ford Shale formations in the Dakotas and S. Texas. As more oil drilling and production ramps up in oil shale(the Tuscaloosa shale drilling is just ramping up as I type this here in S.Louisiana), look for the prices to fall, just like they did in the past 6 years after the natural gas shale drilling took off. The low price you're paying now for CNG is a direct result of the boom in shale gas drilling. Prices have fallen from the $8-9 range down into the $2 range it is today.
Update on our CNG Systems.
The Truck is getting three more MPG around town running on CNG.
It has more torque than on Gasoline and is much more quiet.
In fact now when driving around town I can hear the Power steering pump and the belts working. I can hear the break booster and a host of other new sounds that were drowned out by the engine on Gasoline.
The Octane rating for the CNG I buy from PG&E is 128 and that ends all the pings of the engine when under load.
I just got my first statement from PG&E and it was for $55.96 for 33 Gallons of CNG.
Over all the truck runs smoother and has more low end power and cost much less to operate than with gas.
I plan on doing a video tomorrow with the truck running on CNG and showing all the systems working.
Joe
Joe
akamacgyver
16
Apr 15, 2011 10:07 PM
T8R
Mar 5, 2010 11:22 AM
