1978 - 1996 Big Bronco
push button 4 wheel stuck in 4Low
Old Feb 14, 2012 | 07:19 PM
j.dogg.welding's Avatar
j.dogg.welding
i have a 1987 with a 302, auto trans.
its sat for a few years, just got it running again
but its stuck in 4low.
there are no lights on in the dash saying its in 4x4 or 4low.
now i dont know if its fully electric actuated transfer case or
what, i am not to familiar with this body style truck.
any help would be much appriciated
thanks
Old Feb 14, 2012 | 09:00 PM
GruesomeJeans's Avatar
GruesomeJeans
Are there manual lockers on the front axle? You might also climb under and see if there is any linkages or something you could fiddle with.
Old Feb 15, 2012 | 12:08 AM
greystreak92's Avatar
greystreak92
If there is no transfer case lever in the floor of the truck, the t-case is fully electronic and disengagement should be immediate. Backing up about 10-15 feet might help but typically this is done more to disengage the so-called "automatic" front hubs (junk). The control module for the electronic t-case is behind the passenger side kick panel near the floor. With the electronic cases though, the most common failure point is a jammed shift motor. they often get stuck "between" shift points. When this happens, the control module "knows" it and will not send electricity to the shift motor to keep it from damaging the t-case. The only way to fix it is to either remove the shift motor, lubricate the mechanism and re-install it with the armature rotated to the 2WD position.
Old Feb 15, 2012 | 10:52 PM
GruesomeJeans
Wow that sounds like a lot of work.
crzyjy63919140
Bronco II
Feb 15, 2010 02:56 AM
jem44357
Jan 27, 2010 09:13 AM
BINGO KING
Nov 26, 2006 07:13 AM
topdeadcenter
1997 - 2003 F150
Mar 8, 2004 03:40 PM
