newbe needing some help.
Old Feb 13, 2012 | 10:49 AM
docrw1's Avatar
docrw1
Hi I am new to the site and been reading some very good info but have landed in a mess. Just built my 2.3 in a 85 ranger. The issue is the truck runs great when cold but after running a few min it starts missing on number 2 cylinder. Have checked spark when it does it and it is firing. It seems to be getting to much fuel on that one cylinder. Any suggestions.......
Old Feb 13, 2012 | 04:12 PM
Phinxter's Avatar
Phinxter
How do you know it is on cyl #2? Does it happen idling or under load? What makes you think it's getting too much fuel?
Old Feb 13, 2012 | 05:09 PM
docrw1's Avatar
docrw1
I can pull all plugs and Only number 2 is dripping in gas. Can clean plug and put back in motor and it runs fine for a few min then it starts missing on that same cylinder. Like today. I let truck set over night with battery disconnected. Started truck up and it ran great for about 5 min then #2 went dead. Can pull injecter wire or plug wire and there is no change. If you hold accelerator say half throttle it runs fine then starts slowing and missing. This is a fresh build. New everything. New map sensor, new iac, ect, and o2 sensor is new. Have never seen such a thing.
Old Feb 14, 2012 | 12:25 AM
michigan66's Avatar
michigan66
Sounds like you have a bad injector.
Old Feb 14, 2012 | 05:07 AM
docrw1's Avatar
docrw1
Their new. You can move them around and problem stays on number 2 cylinder. Check compression and all cylinders are at 150 psi.
docrw1
4 Cylinder Engines
Feb 13, 2012 10:55 PM
swift722
17
Feb 6, 2010 08:55 AM
SMiddleton
Sep 21, 2008 08:38 PM
bgirard78
Dec 17, 2007 06:33 AM
Cav
Jan 5, 2005 08:19 PM
