6spd/ clutch problems
Old Feb 12, 2012 | 12:59 PM
McKenzie7.3's Avatar
McKenzie7.3
i changed the clutch on my 2000 7.3 when it got really bad, when i pulled out the old clutch 1 spring had broke out and another one was half out, the pilot bearing was literally gone and there was metal shavings everywhere in there. (this was a week after i bought the truck) i also changed the master and slave cylinder prior to changing the clutch. once it was all together it seemed perfect for about a day, then started grinding a little bit when shifting, mostly going into third, but other gears also. shift forks mabey??
Old Feb 12, 2012 | 01:26 PM
bfife's Avatar
bfife
still plays with trucks
how did the clutch fork look? there have been issues in the past with flexing or broken clutch forks. ford released an updated version in 01 I believe
Barney
Old Feb 12, 2012 | 01:51 PM
McKenzie7.3
well i didnt take much time to look at it but seemed fine to me, after i got it together i heard the clutch fork is weak for my year of truck, i suppose ill have to pull the tranny again either way
thanks
colton
Old Feb 12, 2012 | 01:55 PM
1996pwrstrk's Avatar
1996pwrstrk
What did you use a pilot bearing or a bushing ? Was the end of the input shaft really rough ?
Old Feb 12, 2012 | 01:57 PM
McKenzie7.3
i beleive i used a bearing, and it was rough but not to bad
Old Feb 12, 2012 | 04:06 PM
helifixer's Avatar
helifixer
check the rod where the master clips on under the dash, if it is run with a bad bushing it will eat up the rod on the pedal,(this fixes that problem) ( FORD Clutch Rod End PERMANENT Repair powerstroke too. | eBay ) also check where the shaft goes through the pedal box, those bushings wear out and elongate the hole in the pedal box.
dizzyfingers03
38
Mar 16, 2011 01:27 PM
charlessocccer
34
Dec 15, 2010 03:17 PM
svcguy
Oct 8, 2010 12:33 PM
drillerdan
Nov 15, 2004 08:51 AM
sobsidian
1983 - 2012 Ranger & B-Series
Apr 30, 2004 10:03 PM
