02sensor plug melted
Old Feb 12, 2012 | 12:37 PM
Smokebomb289's Avatar
Smokebomb289
2008 5.4 passenger side upstream 02 sensor plug coming from main harness melted to my manifold. Can the wires be connected directly? From 02 wires are black, grey, white, and white.. From the main harness wires are red with white stripe, red with yellow stripe, grey with red stripe, and brown... No idea what goes where....... Any ideas???
Old Feb 12, 2012 | 12:56 PM
Smokebomb289
Come on guys.... Help a brotha out!!!!
Old Feb 13, 2012 | 02:35 PM
Blue Eyed Cyclops's Avatar
Blue Eyed Cyclops
Absolutely, you could even use crimp connectors as long as you find out which wires to connect. Will you be able to keep the wires away from the manifold, so the insulation doesn't get burnt? Maybe splice in some additional wire so you have more length to keep the wires away from hot things.
Old Feb 13, 2012 | 04:27 PM
skunkoffroad's Avatar
skunkoffroad
Probably the best way to find out where the wires go If you get under another truck with a pen and paper and see which wires connect to which. If you don't have a friend with a similar truck I would just go to a dealer and crawl under 1 but hopefully somebody on here will do it and post it 4 you.
lightflyer
Nov 20, 2016 09:17 AM
Archer379
Mar 18, 2012 05:34 PM
1buckeyefan
Jan 18, 2011 01:29 PM
Tattooed_countryboy
Electrical Systems/Wiring
Feb 18, 2008 07:02 PM
STGFordCrazy04
Jul 14, 2006 08:26 PM
