Next time try this with your HVAC set to VENT or FLOOR. If it changes to the DEFROST position as you attempt to engage the front axles with the hubs set in the AUTO position, it sounds like you have a weak PVH (Pulse Vacuum Hub) solenoid that is in need of replacement.
Ha! Mine has done this and I couldn't figure it out. You da man! It does it intermittently also. Wonder how much that PVH retails for?
The part number is 7C3Z-9H465-A. Price it out at your local dealer or partsguyed, whichever is cheapest for you. If you really want to test it, borrow a known good one from another truck to swap in temporarily to see if it repairs the issue. Replacement of the part is schoolgirl simple if that describes it well enough.
Thanks again reps given! Bought new PVH and swapped it out, fixed my issue! You da man!
Would a compromised pvh solenoid fail instantly or fail over time? I have what I believe to be a vacuum leak, just been dealing with it. The vacuum pump tested out and runs like it should. I've searched all visible lines I could find but other research I've tells me some vacuum lines run behind the dash and can fail behind the dash. When i started losing AC and all other air through dash vents it wasn't an over night thing it seemed like it took time for me to lose it, sometimes it would come through dash sometimes it would come through defrost only until finally it all started coming through defrost only. Thanks.
mine was over time as well, pretty much how you described, but i too had a/c door problems under warranty and according to the dealer it was a leak behind the dash, the symptoms of the pvh were when i engaged the esof while driving with the a/c on ,the a/c would shift from vents to defrost, i started thinking the esof switch was a defrost switch. so in my experience it was slowly over time and intermittent. but i am not sure if i had 2 seperate issues
The tires and axles have to be spinning for them to engage, in other words once your stuck your stuck. I have witnessed on 2 separate occasions a 7.3 and a 6.0 get stuck in sugar sand next to my house they engaged the ESOF and tried manually locking hubs after it was stuck and it would not engage. This is why i engage mine before I pull my TT Anywhere near offroad. Unless these trucks were both broken by coincidence
Man I guess I thought wrong I thought once you manualy locked them in they would be locked
Interesting
This has been my observation twice on two different trucks. One a 7.3 and one was a 6.0. They both got stuck then engaged the ESOF. And you could see the front tires never spun, after finding the problem with my trucks PVH, it might be that these 2 trucks both had bad pvh's as well but this has been my hypothesis after seeing this, as well as reading of similar experiences on this forum. And after we got both trucks out the 4x4 worked, the 7.3 I tried locking the hubs. Putting the trans in neutral, park, reverse. then I gave up and pulled him out. Then I told him to get a 6.0
I know I've seen this observation posted a lot. But I've never seen anyone post any sort of reason, description of how the hubs work, documentation, or really anything else that would describe or explain why this would happen. I also know that it's never happened with my truck and I've been stuck more than a few times.
Personally I think there is something wrong in the hubs if this is happening. The hubs are fairly simple, when you turn the dial you turn in the locking ring that engages the hub. Perhaps if the hubs are not lubricated properly, the ring won't push in easily and some vibration will help them along. If this is the case, the hubs need maintenance.
When I did my BallJoints not to long ago and had the Hubs out I was pretty shure when I turned the Hub from auto to lock manually it was locked in imediatly at that point the hub required no rotation to engauge.
What makes sense cuz by manualy turning the hub from auto position to lock position you rotated it the required amount to engauge the hub at that point
So now that this has been brought up that it has to spin so far to engauge made me start to think that its not a Hub thing by not locking into 4X4 right away but a Transfer case issue needing the revolution to Engauge.
But also once I turn the 4X4 switch in the cab from 2WD to 4WD the transfer case should Electronicaly engauge the transfer case imediatly as well
I was going to mess with it tommorro by trying to engauge 4X4 without moving the truck.
To Prove the spin theory right or wrong
IMO it should be able to Lock into 4X4 without moving
I did a google search on this issue after posting, and you can find a lot of other posts in other forums of similar findings. So I'm not sure if this is by design, or if it in fact does indicate an issue with the 2 trucks I have seen and I have noticed prior to replacing my PVH similar distance before my 4x4 engaged, I have not tried it since, I have been turning on the 4x4 when towing my trailer well before I pull off pavement to ensure it engages. Let us know what you find Benny. I thought the same thing when I locked the 7.3 hubs when he was stuck and it still wouldn't engage. then he called me the next day saying it worked fine the next day, only difference was this time truck wasn't stuck when he tried it.
I went out and Manualy turned each Hub to lock position 1 hub was imediatly locked and the other hub Locked in as I spun the axel at the Ujoint it didnt spin very much though maybe 1/8 of a turn but very little. At this point I could NOT spin the front axel shaft by hand anymore and the 4X4 switch in the cab was still in 2WD and Gearshift in park maybe I needed to spin the axelshaft harder I kinda thought that I could spin the axel shaft untill I turned the switch in the cab
I was thinking that I should of been able to lock the hubs and still be able to spin the axel shaft untill I swithed the 4X4 switch in the cab and engauged the transfer case IDK Maybe I needed to spin harder
So I will have to come up with a Diffrent way to test didnt have much time today
No, what you did provided normal results. The first hub locked in immediately. That's normal. The second hub took a small amount of axle spin. This is because the hub splines don't always line up, but a small amount of axle spin allows the splines to match and it locked. With both hubs locked, the front drive axles and drive shaft turn with the front wheels. Which means that if the front wheels can't turn, the axles and drive shaft don't turn. The front axles aren't connected to the main drive line, because the truck is in 2WD. But the axles are connected to the wheels.
So if I am understanding you correctly, that there is play in both the hubs, that lock the wheels to the shaft, and play in the transfer case, and both require a limited amount of spin or wheel turn in order for it to engage, so it then makes sense that if you are already stuck that, the front tires will not be able to spin enough to engage to get you out, so always engage it before you think you might need it, and all of this requires you don't have a vacuum leak somewhere that would prevent any of this happening.
Oh yes your right didnt think of it like that but your ABSOLUTLY RIGHT
Duh My Bad
I was thinking I need to get the Front wheels up off the ground Then try the same thing now that you pointed out my problem with the test Im positive I need to get the front tires up off the ground
