Modular V10 (6.8l)
Tuner question
Old Feb 10, 2012 | 07:36 AM
mudfuel06's Avatar
mudfuel06
Tuner question
When I had the stock size tires on my truck, the speedometer read about 4-5 mph faster than I was actually going ie.-read 45mph when I was actually going 40. I put larger tires underneath the beast (295/70R18 Trail Grapplers) and the speedomter is reading correctly. Would you change the settings in the SCT to reflect the larger tires or just leave it alone?
Old Feb 10, 2012 | 11:16 AM
dkf's Avatar
dkf
The SCT will adjust the shift points and etc. Shouldn't affect the speedo reading at all. Change the ratio a double check the mph reading to see if its the same.
Old Feb 10, 2012 | 04:41 PM
Bbasso's Avatar
Bbasso
I would call Mike and ask...
Old Feb 10, 2012 | 05:37 PM
dkf's Avatar
dkf
Its not like you are going to hurt anything by changing the ratio and reflashing the truck. You can put it back the way it was with another reflash. SCT usually doesn't mess with the ABS system because of liability concerns thus why they usually cannot adjust the speedo.
AlaskanEx
Jul 26, 2018 01:05 PM
Skygrasper
Sep 4, 2016 03:38 AM
truck7575
Nov 1, 2012 09:36 AM
MRyanF
May 27, 2008 06:41 PM
joediesel
Dec 16, 2007 11:13 PM
