94' Explorer wont start
Old Feb 9, 2012 | 03:22 AM
SirArgus's Avatar
SirArgus
A friend of mine have a 94' Explorer with the 4.0 v6.
fuel pump starts for 2-3 sec when i turn the key, stops when cranking and starts again when i stop cranking. i checked the fuel shutoff switch and it was ok, and it have spark.
Any ideas?
Sorry, my english is not very good :P
Old Feb 9, 2012 | 06:53 AM
shorod's Avatar
shorod
Sounds like you might have an issue with the ignition switch (not the key cylinder switch).
Have you tried spraying some throttle body cleaner in to the intake when cranking the engine to see if it will start when it has fuel? Do you have a fuel pressure gauge that you can measure the fuel pressure with?
-Rod
Old Feb 9, 2012 | 03:24 PM
SirArgus's Avatar
SirArgus
-Rod
I dont have a fuel pressure gauge, i'll try and see if it will start with throttle body cleaner tomorrow, i think it will, since it does have spark.
is there a fuel line in the engine bay i can take off to see if the engine gets fuel?
Old Feb 9, 2012 | 07:52 PM
aquanaut20's Avatar
aquanaut20
Having fuel flow does not equate to having pressure as required by injectors... Philip
farmerwill
May 6, 2012 05:24 PM
Explorer180
Mar 15, 2011 10:32 PM
jkarne
Jun 15, 2010 06:50 AM
steadtech
Mar 19, 2010 07:07 AM
edsblue67
Jun 8, 2004 07:58 AM
