1978 - 1996 Big Bronco
tcase problems?
Old Apr 22, 2003 | 11:05 PM
rcoll90's Avatar
rcoll90
tcase problems?
I have an 88 bronco eddie bauer with a NP 208 tcase. I can't shift into 4wd. The manual hubs are locked and the linkage moves but the shifter doesn't stop at 4hi, or a neutral or 4lo when my tranny is in neutral. I can spin the drive shaft and hear fluid turning, but no four wheel drive. Can someone help?
Old Apr 22, 2003 | 11:48 PM
steve83's Avatar
steve83
tcase problems?
Get under it on the driver's side and see if the shifter is still connected to the t-case.
Old Apr 23, 2003 | 12:06 AM
rcoll90's Avatar
rcoll90
tcase problems?
it is connected and i can see it moving along the tcase
Old Apr 23, 2003 | 07:48 AM
steve83's Avatar
steve83
tcase problems?
Then you have a big problem inside the t-case. A replacement will probably be cheaper & quicker than a repair, and then you'd have all the time you need to tear that one down and fix it as a spare for next time.
