electrical issue solved. One new query.
Old Feb 8, 2012 | 07:38 PM
jerkypants's Avatar
jerkypants
The electrical issue (power windows, map lights, radio, dash issues)
I found while working on no start. A bad ground between the cab and frame on passenger side. Replaced it and electrical issue gone. Seen the same question on here a few times.
New query: Still have a no start, the ficm is fine. This all started with a p0460 if I have the code # right, but it was for - fuel level sending unit cicuit. Is there a wire or connection from the sending unit to tje fuel pump that shuts the pump down when the sensor is gone? What are the three electrical connecters that go to the HFCM?
Just trying to figure it out b4 I have to take it in.
Thanks everyone, Jerky Pants or gianni
Old Feb 8, 2012 | 10:07 PM
1BadHabit's Avatar
1BadHabit
One is the fuel pump power (from the fp relay in the power distribution box).
One is the Water In Fuel indicator circuit.
One is the fuel heater.
Someone else will have to answer if the power to the pump is shut off when there is a fuel level sending unit error.
Take the cap off the secondary fuel filter housing on top of the motor. Have someone else turn the key on and see if fuel is rapidly filling the filter reservoir. I recently had an issue of a fuel pump that was either weak or working intermittently.
Old Feb 8, 2012 | 10:41 PM
jerkypants's Avatar
jerkypants
Thank you, it seems plausible to me that the pump would have the capability of shutdown
Is there an inline fuse to the fuel shutoff switch?
Old Feb 8, 2012 | 10:57 PM
1BadHabit's Avatar
1BadHabit
The wiring diagram doesn't show the fuses, so I'm not sure where in the system they are tied in exactly. There is a fuel pump fuse (20 amp) in the panel under the dash, and a HFCM fuse (30 amp) in the power distribution box under the hood. I'm not sure if the HFCM fuse is for the heater or the pump.
The power from the fp relay goes through the fuel shutoff first and then to the pump.
Old Feb 9, 2012 | 01:12 AM
f350ranchand's Avatar
f350ranchand
I have the same problem with the no power to the radio windows and map lights I have wired the windows and radio to wur they work but still no map lights anybody know wur any other grounds might be other than the one mentioned in this post
Old Feb 9, 2012 | 05:19 AM
critterf1's Avatar
critterf1
P0460 will not cause a "no" start. Check fuse #40 under dash.
fordexplorersport
Feb 11, 2016 06:55 AM
Critterhunter
1983 - 2012 Ranger & B-Series
Jun 17, 2015 05:11 PM
95blackf-150
16
Dec 17, 2011 12:46 PM
Powerstroke-7.3
13
Dec 29, 2009 02:45 PM
matthew
Jun 2, 2000 07:28 PM
