transfercase
Old Feb 7, 2012 | 09:17 PM
austinlibke's Avatar
austinlibke
transfercase
I currently have a '90 f250 that has the 5.0 and has the Mazda 5spd. with the BW1345 behind it. I recently bought a 460 with a ZF s5-42 and a BW 1356.. For simplicity reasons, i want to put the BW 1345 behind the ZF, My question is if the 1345 is strong enough to be able to put up with the bigger engine and transmission.. if it is even possible to change out the transfer case .. Please help, and Thank you.
Old Feb 7, 2012 | 09:50 PM
SCRebel's Avatar
SCRebel
Yes you can swap the BW 1356 for the BW 1345. The 1345 can handle it, and will do everything you need it to.
Are you putting the 460 in your F250?
Old Feb 10, 2012 | 06:22 PM
austinlibke
That is currently my plan, yes
Old Feb 10, 2012 | 06:28 PM
austinlibke
Old Feb 10, 2012 | 09:15 PM
SCRebel's Avatar
SCRebel
The 1356 and 1345 arn't really much different. Really the only big difference I know of it the 1356 has a slip joint for the f150.
If you are concerned that the 1345 can't handle the torque of the 460, you can get a W 1356 out of a 90's model Bronco. The Bronco had the fixed flange.
Old Feb 10, 2012 | 11:34 PM
RJJP's Avatar
RJJP
Some of the F250s and F350s had the slip yoke as well.
Old Feb 10, 2012 | 11:37 PM
SCRebel's Avatar
SCRebel
I thought they might but I wasn't sure. I knew they came under the F150. Personally I like the fixed flange or fixed yoke better.
Wyofordguy
Engine Swaps
Feb 1, 2016 03:17 PM
Sycostang67
Feb 6, 2007 01:10 AM
1973F250CREW
Sep 27, 2006 07:20 AM
SR71
Apr 13, 2003 12:53 AM
cleancut
Feb 13, 2001 10:04 PM
