code problems again
Old Feb 7, 2012 | 03:31 PM
2005f-150's Avatar
2005f-150
code problems again
all the truck info is in my sig. i am getting code 122-tps signal to low, witch i think the tps is bad due to the way it runs so i am going to replace it with a motorcraft one. code 172 but i am going to follow xc4jokestomper's post to figure that one out (i think it is to replace the o2 sensor)but i am also getting code 212-loss of diagnostic monitor signal short to grounded output what does that one mean?
Old Feb 7, 2012 | 04:59 PM
rla2005's Avatar
rla2005
Code 212 indicates the PCM is not seeing the IDM (Ignition Diagnostic Monitor) signal. What color Ignition Control Module (ICM) is in the truck? It should be black (CCD-style). A gray (Push Start-style) ICM will trigger this code in your vintage truck.
A missing SPOUT connector or poor connection can also trigger Code 212.
Old Feb 7, 2012 | 05:23 PM
2005f-150's Avatar
2005f-150
its grey, i think i have a black one lying around somewhere ill try. thanks for the help
RDC F250 7.3
Oct 8, 2007 10:00 AM
cvranger
1983 - 2012 Ranger & B-Series
Jul 3, 2005 02:43 PM
RTM
Jan 12, 2004 06:54 AM
