4WD Actuator Removal
Old Feb 6, 2012 | 08:29 PM
lovemyexpy's Avatar
lovemyexpy
Question 4WD Actuator Removal
After a couple years of having to periodically un-freeze my 4WD Actuator piston I finally decided to replace the actuator. I made an attempt at it yesterday, but found that the brass sleeve is literally fused into the aluminum housing it protrudes through.
Has anyone had a similar issue? I tried PB Blaster and heat, but no luck so far. There is not much room to work with to hammer the sleeve out. I am thinking of cutting the actuator at the sleeve where it enters the aluminum housing to acquire some more room. If I cannot get it out, I will resort to drilling some holes through it to weaken it enough and take it out in pieces if necessary.
Here is a link to the actuator I have as a replacement. It has the same brass sleeve:
More Information for DORMAN 600300
Any and all advice appreciated.
Thanks......
Old Jul 23, 2012 | 08:48 AM
lovemyexpy's Avatar
lovemyexpy
I thought I would answer my own post in case others ran into the same issue. I ended up cutting off the old 4WD actuator (reciprocating saw) on each side of the aluminum housing it is inserted through. This will leave you with a brass sleeve and the actuator rod inside it. The actuator rod will slide right out. You can then drill out part of the brass sleeve (I used a 1/2" drill bit), which leaves about 1/8" thickness of sleeve. I then took a hack saw blade and scored through the brass down to the aluminum in two places about 1/8" apart. I could then punch that piece out with a hammer and screwdriver. I scored one more 1/8" piece to attain about a 1/4" opening in the sleeve. I was then able to collapse the sleeve on to itself (using a hammer and screwdriver again) to pop it out of the aluminum housing.
Hope that helps someone in the future
Old Jul 23, 2012 | 10:29 AM
bowesmobile's Avatar
bowesmobile
Thanks for the reply and fix. That is a crappy way to have to remove a sleeve. Good to see you were able to get it replaced!
Old Jul 23, 2012 | 11:20 AM
catmandu1999's Avatar
catmandu1999
Double thanks, bet it will help when I tear down my 97 f250.
Also, lovemyexpy check your or my visitor messages for clarification about the squeak I was asking you about.
putter53
1997 - 2003 F150
Nov 20, 2007 12:22 PM
nightshifter
Aerostar
Oct 4, 2004 12:35 AM
Beaned
Aerostar
Aug 25, 2004 08:26 PM
