NO electrical power at all
Old Feb 6, 2012 | 06:17 PM
Schuby's Avatar
Schuby
Hi guys...i need some serious help on my 06 4cyl Fusion. I know this is a truck site but I have recieved good help from this site in the past on my truck and i dont know were too turn except here. My fusion is dead after I crossed the cables jumping it in the dark ( and being upset at the same time). Anyway I have checked fuses in the distribution box with volt meter, took out battery and tried jumping strait to battery terminals...NOTHING. It wont crank, no lights, no sounds. I dont know were to go from here, i dont want to get it towed to dealer cause it will be mainful, money wise. Any advice would be cherished
Old Feb 6, 2012 | 06:48 PM
Franklin2's Avatar
Franklin2
You checked the fuses with a voltmeter. Did you check them for continuity using the ohms scale? If so, why don't you check the fuse sockets for power. If they are all dead, that means the fuse box is not even being powered, and you need to look upstream. Go to Autozone's site and see if they have any diagrams of your car.
Old Feb 6, 2012 | 06:56 PM
Schuby's Avatar
Schuby
yes i checked using the ohms...do you check the box the same way as the fuses? i will check auto zone. Is there a another fuse between battery and dist. box?
joeimp
Electrical Systems/Wiring
Jan 15, 2018 07:33 AM
Crewdcab
Apr 28, 2016 12:01 PM
91 blowncoupe
Escape & Escape Hybrid
May 17, 2009 01:44 AM
scottya4
16
Sep 10, 2004 08:29 PM
tetraruby
Aug 5, 2002 01:47 AM
