Calling all Scangauge users!
Old Feb 7, 2012 | 01:22 PM
Seabiscuit-P3's Avatar
Seabiscuit-P3
Veteran: Navy
Veteran: National Guard
Originally Posted by DIYMechanic
Yeah, that's what I thought. I guess I didn't realize these Scangauge II's would supposedly work on a PSD. Anynbody have one they have tried on a PSD?
The scangauge II doesn't really work, at least on the 96 PSD. IMHO it should not even be listed as a gauge for the 96. (I did plug it into my son's 2002 F150 and it seemed to work as advertised so I'm going to give it to him.)
It was a waste of money for my 96. Here's some email communications I had with them when I could only get a very few minimal functions to work..........................
"Thank you for your inquiry. I apologize about the delayed response. I spoke to our engineers regarding your issue. They would like you to try a special command. From the home screen (the button with the red circle around it) from there select MORE> MORE> COMMANDS> EDIT> choose a MEMORY slot> EDIT> use the plus or minus sign to scroll through characters and enter 616AF103> SEND. After you send it, please write down whatever comes up on the screen. It will be the raw trouble code response from the ECU. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Leah O'Campo
Director of Communications
Technical Support
Linear Logic
1.888.433.5664"[/FONT]
"Tried the special command in Memory 0 and Memory 1. Result was a blank screen with OK in the lower right corner and the arrow indicating to push the button just above the menu button which takes it back to the select and edit screen.
Still shows 74 codes in the scan mode. Code and Stored Codes don't show any codes and Clear comes up No Response.
Jim"
]"I spoke to our engineer regarding your issue and he said that the unit is most likely acting weird because the Ford, GM, and Dodge diesels for that year were not required to be fully OBD2 compatible. Because of this, he really has not other solution. [/FONT]<o></o>
Leah O'Campo
Technical Support
Linear Logic
1.888.433.5664
Old Feb 7, 2012 | 04:11 PM
DIYMechanic's Avatar
DIYMechanic
That tells me exactly what I needed to know. Thanks for chiming in with the first hand info. Reps sent.
Old Feb 7, 2012 | 04:46 PM
mjonesjr's Avatar
mjonesjr
The Aeroforce Interceptor WILL work on a '94.5+ PSD.
I am running 2 of them on my '97. I am also running a boost PSI, fuel PSI, and EGT sensors on mine as additional gauges that the PCM doesn't read. I got rid of 4 gauges with the 2 Interceptors and I have a lot of other info I can display.
The Interceptor will see and display any parameter that the PCM sees. It will also do buzz & CCT test along with checking and clearing DTC's.
run6.0run
Jul 26, 2014 10:47 PM
NMB2
Apr 3, 2012 08:07 PM
kawa
64
Jan 3, 2012 07:06 PM
97XLT4X4
Mar 29, 2011 06:51 PM
Krisx125
280
Dec 22, 2010 01:05 AM
