Truck not starting
Old Feb 5, 2012 | 10:25 AM
77_150's Avatar
77_150
Truck not starting
Hi all,
Happy Superbowl Sunday!!!!
I had posted about this particular problem a few months ago, but let that thread die since I did not have the required information that some asked for - mainly because I did not know.
Symptoms:
The truck has an Olds 403 engine with a Delco distributor. The truck also has a push button start so you turn the key and push the button - kind of strange.
I found that if I wired the distributor directly from the battery then it starts (just troubleshooting). So I started tracing back the wire from the distributor and it comes into the cab under the dash on the right under the glove box. At first I thought it went directly to the ignition switch, but upon further investigation I see that it does not and continues on in the bundle. Not sure where it goes.
Question:
Is this a symptom of a bad ignition switch? A bad fuse somewhere? (might be a dumb question). A bad wire?
There are a ton of wires all bundled together and I hate to unravel all of that to trace the wire, but will if I need to. I have included a few pics of what my distributor looks like so that it might help determine where the problem is.
Sorry, but I am really new to this and do not know a lot about this kind of problem.
The first pic is the entire distributor. The second pic is a closeup of where the wire connected to the distributor (right hand side) and the third is from the left side.
Sorry about the pics - not sure why they went sideways!
Thanks for you help!
Old Feb 5, 2012 | 11:01 AM
tude's Avatar
tude
Run the dist power wire to a toggle switch and then to the battery..... Should cure it all
Old Feb 5, 2012 | 11:07 AM
77_150's Avatar
77_150
You know - that might just do until I can get rid of the engine and put a ford engine in there. That has been my goal.
Thanks!
Old Feb 5, 2012 | 11:53 AM
tude's Avatar
tude
I'm not knocking it..... I'm a if it ain't broke don't fix it guy. I'd wait to mess with it till something died on it major personally
It will work, we do it all the time
Old Feb 5, 2012 | 12:29 PM
77_150's Avatar
77_150
Nope - totally understand and I am good with it too. Problem with having an off brand engine in there and posting on a Ford forum is that there may not be as much expertise as there would be with a ford engine.
Old Feb 5, 2012 | 02:01 PM
77_150's Avatar
77_150
Put that switch in and it works great! Thanks for the tip. This will get me through until I can restore it all back to original.
Mike
Old Feb 5, 2012 | 03:08 PM
tude's Avatar
tude
If you want a push button that won't fail go to napa and get an ST6 push button. Then just hook your existing wires to it. It looks like a dimmer switch, best I have found.
Old Feb 5, 2012 | 03:09 PM
tude's Avatar
tude
Glad to help
jerryst
Mar 28, 2017 02:25 PM
Jeff K
31
Oct 21, 2013 02:49 PM
1972-34ton
Apr 24, 2009 08:35 PM
302 F-150
Electrical Systems/Wiring
Jun 16, 2007 09:23 AM
79BigBlock4x4
Mar 6, 2005 10:30 PM
