At first I was running a BDS 8" all leaf kit with 37's. I only had alittle rubbing on the front end at full lockout.
The lift was all in all good to go! No probs.
Around the time I added the Road Armor bumper I installed a 2.5" front shackle kit...and added a 5.5" block to the rear.
So I guess as we speak I have a 10.5" lift with plenty of wheel travel. When it's time for new tires I will be moving up to Nitto Mud 38's or 40's.
Thanks for the info Dvldog. I appreciate it especially from a fellow X owner in NJ like myself.
Where in NJ are u?
Yeah I went with the Ex lift.....but I should have went with the 10" the 1st time around. I would have saved time and money.
Also, the rear driveshaft has to be lengthened. ( serious vibration if u dont ) The front was good to go. When I moved up to 10" I needed a longer one.
Keep us posted and take alot of pics of the build!
Where in NJ are u?
I'm in South Jersey about 30 miles outside of Atlantic City. I definately plan on taking alot of pics. I'm just trying to get enought posts to post a signature first
So if I go with the 8" kit I will need a longer rear shaft? Whats a ballpark on the rear shaft cost?
Thanks again for the great info and your service to this great country
I have a 7" lift on mine. I had 37's on it with like dvldog only a little rub at full turn on the spring. I went to a 36" tire but over the fall I sold them and getting 37" swamper M-16's
Semper Fi
I used a shop called Mr. Driveshaft in Wall Township. I think it was around $300 with new Spicer u-joints out the door painted, ready to install.
I'll see if I could find a link for ya.
Thanks for the info High Intentions. It seems I'm getting help from the local guys..NJ and PA
I have an 8" with kuhmo 37's (which i dont recomend, my last Toyo's were way better riding and wearing). I dont have any rubbing and did not lengthen the driveshafts.
Thanks for the info..Do you have any pics yopu can post?
6" Procomp with 37" Toyos on 17's. Rubs slightly on the springs at full lock.
Thanks for the info Arch, your X looks great. I really like the black wheels on the truck. If you did the lift again would you have gone with the 8" lift?
