high mount brake lights
Old Apr 22, 2003 | 02:39 PM
sdjewel's Avatar
sdjewel
Question high mount brake lights
Can someone please tell me how do I remove the cover to replace the high mount brake lights on my 98 explorer sport??
Thanks
Old Apr 24, 2003 | 06:13 PM
MarkMatthews's Avatar
MarkMatthews
Cool high mount brake lights
I have a '96 Explorer and the high mount brake light went out. This is how I got to it. I have not fixed it yet because it's a neon light with a transformer. I always thought it was an LED array. Ford says the transformer is $101.00 I have not priced the light yet.
If you open the back hatch there is a plastic cover between the window and the hinges. It is part of the inside plastic cover on the entire hatch and goes all the way around the window. I just removed the 4 plastic friction bolt thingies (I don't know the technical name) that cover the light, they just pull straight out, you will find what looks like a black panel secured by two phillips screws. This is the transformer. Remove the two screws and remove the unit - 1 power "in" with a clip and two power "outs" which just pull apart. On either side of the hole in the frame there is a 1 1/2 rubber stopper. Pop these out and you have access to the 3 nuts holding the light in - one was behind the transforner.
Chances are that the transformer is bad and not the light.
If anyone knows how to test this let me know.
Good luck!
shargue
Electrical Systems/Wiring
Aug 13, 2017 07:38 PM
12engine
Jan 12, 2017 09:56 AM
randy314
General Automotive Discussion
Oct 4, 2015 06:09 AM
MarkF250
23
Jun 30, 2011 07:14 PM
95ExpSport
Jun 13, 2004 09:33 PM
