89 Bronco - Heater Core Installation??
I was wondering if anyone can tell me where the heater core is located on a 89 full size Bronco??
Is it hard to install??
Any help would be greatly apprecicated
Thanks
Raymond
Heater core on the Bronco is a breeze:P
1. Undo your heater hoses under the hood.
2. Go inside, take the glove box door off. You'll see a black plastic
enclosure right behind the glove box area. Undo the screws - 8mm
hex head if I remember right.
3. After removing the cover, you'll see the heater core. Be careful
when you take it out - it's still gonna have coolant in it. Tip
it back when you take it out.
4. As the manuals say-"Installation is the reverse of the above."
Honestly, it's about 30-45 minutes to swap it out....
Hope this helps
msautry
