'97 antenna & base recommendations
Old Feb 1, 2012 | 10:41 PM
little_mule's Avatar
little_mule
Got a '97 E-350 Club Wagon sans antenna base (haven't checked to see if the cable is still okay). Only one parts store around, NAPA but they don't show a vehicle specific antenna.
Any AM/FM antenna suggestions (online or napa)?
Old Feb 2, 2012 | 05:48 AM
JWA's Avatar
JWA
If its just a stock replacement antenna maybe try Horizon Ford in Seattle, WA ? I've used them a few times all the way here in Ohio and they're great.
Also RockAuto.com gets a lot of mention here as a seller of MotorCraft parts---they might have a suitable replacement as well.
HTH
Old Feb 6, 2012 | 02:06 PM
2000Ford2000's Avatar
2000Ford2000
I don't think RockAuto is much good for something like that. Used is the best bet.
I've tried several aftermarket ones on my 2000, but all of them were crap compared to the original. If you're in AK, then this is probably not an option, but I just went to a junk yard and pulled an OEM one. Got the cable and all. Really easy to install it all the way back to the radio. Connecting a new one to the old cable doesn't work good.
You could use car-part.com for a used one and see what they'd ship it to you for. I see one for $10 in GA.
Old Feb 11, 2012 | 01:14 PM
rustypierce's Avatar
rustypierce
98 e150
I went through too many automatic car washes and my base under the chrome cap broke. Went to junkyard and found out that Ford trucks, vans and rangers all have the same base. Popped the cap off and removed two screws for base and pulled the whole assemly out from top. Wire that goes to radio just plugs into the bottom of base. Easy fix with out having to replace wire all the way to radio. base was $5 bucks at junkyard!
oracle
2009 - 2014 F150
Jun 3, 2017 12:15 AM
67nukeford
1997 - 2003 F150
Aug 30, 2015 10:05 AM
78Ranger_GARedNeck
Jun 6, 2008 11:39 AM
hdbadpig
1997 - 2003 F150
Oct 31, 2005 12:36 PM
