Sponsored by: Real Truck
Suspension Help
Old Feb 3, 2012 | 11:44 AM
AirLiftCompany's Avatar
AirLiftCompany
SPONSOR
Originally Posted by JonathanN
You guys now make air bag kits to fit trucks with turnover *****, correct?
Correct, kit 57390 will fit your truck and fit a turnover 5th wheel hitch.
Old Feb 3, 2012 | 12:43 PM
JonathanN's Avatar
JonathanN
Thanks! I'll keep that in mind...
Old Feb 3, 2012 | 08:06 PM
charbaugh's Avatar
charbaugh
The repair kit dzdiggin was referring to is found here.
Ford Superduty Track Bar Repair Kit
It looks like a interesting fix if it addresses your porblem. It owuld be cheaper than a new axle and all the work that goes along with it.
Old Feb 3, 2012 | 08:18 PM
JonathanN's Avatar
JonathanN
Wow... I would totally go for that. I know one of my Dad's company trucks broke the brackets. Mine is just messed up because of how I botched it up... I might post up pictures. Just do me a favor if I do, understand that's NOT how I do things. I don't know what was wrong with me when I did that!
Old Feb 4, 2012 | 07:15 AM
charbaugh's Avatar
charbaugh
Don't worry about judgement here. We all have moments of greatness, and we all have moments of total knuckleheadedness..
Old Feb 7, 2012 | 10:46 AM
Furian's Avatar
Furian
You Keep What You Kill
Originally Posted by Furian
I have contacted Icon asking them if their cross over steerng kit can be used with their 4" lift kit.
Hi Brad,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o> </o>
A fellow FTE user is looking to install your 4” lift kit on his 1999 Super Duty (see link below). He currently has steering issues and I wanted to know if your Cross Over Steering Kit could be installed to address his steering issues. From your response, it is not compatible with his desired setup.<o></o>
<o> </o>
https://www.ford-trucks.com/forums/1135838-suspension-help.html<o></o>
<o> </o>
Thanks!<o></o>
<o> </o>
Andrew Saine<o></o>
Huntersville, NC
<o></o>
From: Brad Myers [mailto:brad@iconvehicledynamics.com]
Sent: Monday, February 06, 2012 11:49 PM
To: a1saine@adelphia.net
Subject: RE: New submission from CONTACT US<o></o>
<o></o>
Hi Andrew, <o></o>
<o> </o>
Can you give us a call….it would seem your question is missing some info. <o></o>
<o> </o>
You would not use the cross over steering until you get into the 10” lift range. <o></o>
<o> </o>
Brad Myers<o></o>
951-689-ICON (4266) <o></o>
iconvehicledynamics.com<o></o>
<?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" oreferrelative="t" o:spt="75" coordsize="21600,21600"><v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><vath o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></vath><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shapetype><v:shape style="WIDTH: 24pt; HEIGHT: 36.75pt" id=Picture_x0020_2 type="#_x0000_t75" alt="cid:image001.png@01CCA60F.FF717E50" o:spid="_x0000_i1025"><v:imagedata o:href="cid:image001.png@01CCE58C.84F5B8A0" src="file:///C:\DOCUME~1\ANDREW~1\LOCALS~1\Temp\msohtmlclip1\01 \clip_image001.png"></v:imagedata></v:shape><v:shape style="WIDTH: 24pt; HEIGHT: 37.5pt" id=Picture_x0020_3 type="#_x0000_t75" alt="cid:image002.png@01CCA60F.FF717E50" o:spid="_x0000_i1026"><v:imagedata o:href="cid:image002.png@01CCE58C.84F5B8A0" src="file:///C:\DOCUME~1\ANDREW~1\LOCALS~1\Temp\msohtmlclip1\01 \clip_image003.png"></v:imagedata></v:shape><o></o>
<o> </o>
From: info@iconvehicledynamics.com [mailto:info@iconvehicledynamics.com]
Sent: Thursday, February 02, 2012 1:45 PM
To: info
Subject: New submission from CONTACT US<o></o>
<o></o>
<TABLE style="WIDTH: 99%; BACKGROUND: #eaeaea; mso-cellspacing: 1.5pt; mso-yfti-tbllook: 1184; mso-padding-alt: 0in 0in 0in 0in" class=MsoNormalTable border=0 cellPadding=0 width="99%"><TBODY><TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes; mso-yfti-lastrow: yes"><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; PADDING-BOTTOM: 0.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 0.75pt; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed; PADDING-TOP: 0.75pt"><TABLE style="WIDTH: 100%; BACKGROUND: white; mso-cellspacing: 1.5pt; mso-yfti-tbllook: 1184; mso-padding-alt: 0in 0in 0in 0in" class=MsoNormalTable border=0 cellPadding=0 width="100%"><TBODY><TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes"><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; PADDING-LEFT: 3.75pt; PADDING-RIGHT: 3.75pt; BACKGROUND: #eaf2fa; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt" colSpan=2>Name
</TD></TR><TR style="mso-yfti-irow: 1"><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 3.75pt; WIDTH: 15pt; PADDING-RIGHT: 3.75pt; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt" width=20>
</TD><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 3.75pt; PADDING-RIGHT: 3.75pt; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt">Andrew Saine
</TD></TR><TR style="mso-yfti-irow: 2"><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; PADDING-LEFT: 3.75pt; PADDING-RIGHT: 3.75pt; BACKGROUND: #eaf2fa; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt" colSpan=2>Email (required):
</TD></TR><TR style="mso-yfti-irow: 3"><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 3.75pt; WIDTH: 15pt; PADDING-RIGHT: 3.75pt; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt" width=20>
</TD><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 3.75pt; PADDING-RIGHT: 3.75pt; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt">a1saine@adelphia.net
</TD></TR><TR style="mso-yfti-irow: 4"><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; PADDING-LEFT: 3.75pt; PADDING-RIGHT: 3.75pt; BACKGROUND: #eaf2fa; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt" colSpan=2>Phone
</TD></TR><TR style="mso-yfti-irow: 5"><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 3.75pt; WIDTH: 15pt; PADDING-RIGHT: 3.75pt; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt" width=20>
</TD><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 3.75pt; PADDING-RIGHT: 3.75pt; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt"></TD></TR><TR style="mso-yfti-irow: 6"><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; PADDING-LEFT: 3.75pt; PADDING-RIGHT: 3.75pt; BACKGROUND: #eaf2fa; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt" colSpan=2>Subject:*
</TD></TR><TR style="mso-yfti-irow: 7"><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 3.75pt; WIDTH: 15pt; PADDING-RIGHT: 3.75pt; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt" width=20>
</TD><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 3.75pt; PADDING-RIGHT: 3.75pt; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt">General
</TD></TR><TR style="mso-yfti-irow: 8"><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; PADDING-LEFT: 3.75pt; PADDING-RIGHT: 3.75pt; BACKGROUND: #eaf2fa; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt" colSpan=2>Message:
</TD></TR><TR style="mso-yfti-irow: 9; mso-yfti-lastrow: yes"><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 3.75pt; WIDTH: 15pt; PADDING-RIGHT: 3.75pt; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt" width=20>
</TD><TD style="BORDER-BOTTOM: #ffffff; BORDER-LEFT: #ffffff; PADDING-BOTTOM: 3.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 3.75pt; PADDING-RIGHT: 3.75pt; BORDER-TOP: #ffffff; BORDER-RIGHT: #ffffff; PADDING-TOP: 3.75pt">Can your SKU# 39500 '00 - '04 Ford Super Duty Cross Over Steering Kit be used with your SKU# 34500 99 '99 - '04 Ford Super Duty 4" Spring System?
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<o> </o>
Old Feb 7, 2012 | 10:55 AM
JonathanN's Avatar
JonathanN
Hmmm... so no go?
wyowelder660
Offroad & 4x4
Dec 10, 2013 09:09 AM
JohnnyAirtime
Jan 9, 2012 05:06 PM
T Price
Modular V10 (6.8l)
Nov 10, 2010 03:23 PM
JonathanN
Jul 21, 2010 07:49 AM
Franken-Truck
Offroad & 4x4
23
Oct 10, 2005 10:07 PM
