Battery drain?
Old Feb 9, 2012 | 09:43 PM
workaholic's Avatar
workaholic
<iframe src="http://www.youtube.com/embed/xpAuqfIOtLQ" frameborder="0" width="640" height="360"></iframe>
Old Feb 10, 2012 | 06:27 AM
cbradford's Avatar
cbradford
Originally Posted by KMUL
Update: the alternator passed a bench test.
The battery drain test produced the following reading: 1.6 on the DMM (200ma setting). Does that mean 160 milliamps?
I was honestly hoping the alternator test would have been a fail, and thus problem solved, easy fix. But nooo... not my lucky day. I don't understand why the alternator passed the bench test, but the voltage reading at the batteries when the vehicles running is only 11.8v.
I guess my next step is to have the batteries load tested.
Note: strange noise when you spin the alternator, sounds like there is a leaf in there or something. Going to get a flashlight on it and have a good look.
I have read here that you can't bench test a PSD alternator, but I don't know as I own a gasser. So maybe do some searches.
I have had the whole system load tested batteries and alternator.
Old Feb 10, 2012 | 09:52 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I had a battery drain problem a few years ago and come to find out it was loose battery connections. The factory connections couldn't stay tight anymore, so I hacked them off and replaced them with some Zinc terminals and I haven't had a problem since.
Make sure your connections are "goodntight" as the German's put it.
Old Feb 10, 2012 | 02:01 PM
KMUL's Avatar
KMUL
Hey guys, thanks for all the good info. I just read on another post that the psd doesn't turn on the alternator until after the glow plugs turn off. That may explain why my voltage reading it was only 11.8, I didn't let the engine run long enough.
Can anyone verify this?
I'm going to test this again later, will let you know. Also going to take the batteries out first though and have them load test. I am now beginning to believe that bad batteries are the problem.
Old Feb 10, 2012 | 08:42 PM
Tailgate77478's Avatar
Tailgate77478
I don't know about that specifically. However, don't forget your alternator is not going to be putting out a full load at idle. I think you're supposed to get it up to about 1100 rpm, if I'm not mistaken.
Old Feb 11, 2012 | 05:27 PM
KMUL's Avatar
KMUL
Final update, 1 of the batteries was dead. Replaced both batteries. Alternator is charging fine. Its still the orig alt with 111k, so I'm sure I'll be replacing it soon.
Lesson I learned here is to test each and battery individually as the first step.
Thanks all for your advice and help.
teppler
Aug 19, 2020 09:55 PM
bdostone
Aug 30, 2017 02:55 PM
Diesel Newb
24
Feb 4, 2013 01:06 AM
99350Ron
21
Feb 3, 2010 10:15 AM
schmity
17
Sep 13, 2006 08:56 AM
