Sponsored by: Real Truck
Understanding auto hub function
Old Feb 1, 2012 | 09:24 AM
Younork's Avatar
Younork
I recently purchased a '04 Super Duty with the factory auto-lock hubs. I've already spent 45 minutes trying to sort through threads about this, and I'm trying to understand how the hubs function.
I was getting them to engage, but they wouldn't disengage, so I didn't suspect a vacuum problem. After reading more, I'm not sure I can discount vacuum.
So I disassembled hubs and cleaned and lubed per Guzzle's instructions, and they still don't unlock.
Now I understand that there is a vacuum pulse to engage and to disengage. My question is: Is it possible get the hubs out of sync with the vacuum pulses when remove and replacing hubs? The plastic detent piece with the pins can be in or out, and does it matter when replacing hubs?
Thanks!
Old Feb 1, 2012 | 09:51 AM
dchamberlain's Avatar
dchamberlain
The system uses a full vacuum pulse to lock and a half vacuum pulse to unlock. I don't have the exact numbers in my head but I can look them up if you need them.
You may have a bad solenoid or a leak. You need a vacuum gauge with a hand pump. The first test I would do is to connect the gauge to the output of the solenoid and have someone shift into 4WD and watch the vacuum pulse. Then shift out of 4WD and watch the pulse. It may take a minute or so when shifting out for the computer to go ahead and send the pulse to unlock the hubs.
Old Feb 1, 2012 | 10:15 PM
Younork's Avatar
Younork
Thanks!
I'll check the vacuum at the solenoid. Now I just need to find my Mityvac.
Old Feb 1, 2012 | 10:22 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
See if this helps.
I need to redo this video.
How To: Find and Diagnose ESOF Hub Vacuum Leaks - YouTube
Old Apr 15, 2012 | 09:28 AM
Dennis Mickle's Avatar
Dennis Mickle
The vac. tubes rusted and was leaking on mine. I replaced them with 1/4" stainless tubing.
Old Apr 15, 2012 | 10:39 AM
Rongold's Avatar
Rongold
HUB OPERATION
Locking of the hubs occurs immediately when you switch to 4WD. Unlocking, according to the owners manual can take a few minutes or more.
RON
254XP3
Dec 13, 2017 08:14 AM
firegod42
Aug 10, 2017 12:08 PM
Younork
Feb 17, 2012 09:28 PM
TNT in Round Rock
Aug 15, 2007 04:10 PM
SteveH-CO
Sep 8, 2005 11:58 AM
