February, 2012 Junk Yard Wishlist
  #46
Old 02-22-2012, 09:57 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
jaluhn,
I think F250 Restorer was at one time thinking about putting together a Gear Vendors overdrive for the C6 in his truck. Perhaps he will see this!
Thanks for sharing your knowledge [and for serving our great country - Navy]!
  #47
Old 02-24-2012, 06:44 PM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
I'm looking for a set of fuel filler necks for an 87 up DRW gasoline engined truck. I would like to have the whole thing to the tank if possible.
  #48
Old 02-25-2012, 10:47 AM
blucollar4xford's Avatar
blucollar4xford
blucollar4xford is offline
Looking for a Saginaw ps pump for a 300-6. Need lines and brackets/fasteners.
  #49
Old 02-25-2012, 08:16 PM
WD4B's Avatar
WD4B
WD4B is offline
Looking for a break drum for a 10" rear break.
  #50
Old 02-25-2012, 10:28 PM
JethroF250's Avatar
JethroF250
JethroF250 is offline
does anyone have a handle on a complete under hood wire harness for a 85 f-250 with a 5.0 fi engine?
  #51
Old 02-26-2012, 12:42 AM
jaluhn's Avatar
jaluhn
jaluhn is offline
Originally Posted by jaluhn
There's also a truck with a C6 2wd to Gear Vendors adapter housing out there. Someone snagged the GV overdrive that was on it but they left the adapter. That's a pretty valuable piece for someone...
I grabbed the GV adapter this afternoon, so just PM me if you need it. Hate for someone to go looking and it not be there.
  #52
Old 02-26-2012, 10:43 AM
85lebaront2
85 EFI harness
If you need the whole harness it is continuous with the dash harness. If you just need the EFI stuff, Archion may have an extra he will part with, I think he has 3 including the one on his truck. To my knowledge 85 and 86 EFI 5.0L are the same and all by themselves.
  #53
Old 02-26-2012, 11:15 AM
JethroF250's Avatar
JethroF250
heres the issue i bought the truck for 650. the guy before me had a carbed 5.0 in it from a mustang. cam factory with efi. he put the efi back in but the wire harness under the hood looks like **** (eg. connectors broken and rigged with splices and half done connectors, and bare wires showing) a good example is the plug for the coil broke in half so the guy used one half and then just put a female connector on the other. def not factory. im picky bout rigged stuff like this. in your opinion should i try and get the whole harness or just the efi? if you think i need a whole harness where should i start looking? thanks
  #54
Old 02-26-2012, 01:51 PM
85lebaront2
The EFI harness plugs into the ignition feed on the left inner fender. It has a connection to the battery at the starter relay and a ground at the battery negative. The harness is in two sections and passes through the firewall by the rear of the left valve cover. The EEC power relay is in there, the fuel pump relay is under the hood on the left side of the firewall under a cover. If the main harness going down the left inner fender looks good, then all you should need is the EFI harness.
  #55
Old 02-26-2012, 02:42 PM
JethroF250's Avatar
JethroF250
ok thanks will post an update when i get back to the truck
  #56
Old 02-27-2012, 10:34 PM
Xenthrax's Avatar
Xenthrax
Xenthrax is offline
Looking for a 1980-1981 Ford truck hood with the F O R D chrome lettering
  #57
Old 02-27-2012, 10:37 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Eeegad! Imagine the shipping cost on that!
80-86 would work, just drill the holes if they're not already there. Barrel nuts to hold the letters.
  #58
Old 03-01-2012, 11:07 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
Closed & superseded by the March, 2012 Junk Yard Wishlist.
ctubutis
11-07-2014 09:30 PM
TAB FFR2086
1997-2006 Expedition & Navigator
01-18-2004 11:26 AM
super_duty_dan
1999 to 2016 Super Duty
10-30-2002 05:14 PM
Quick Reply: February, 2012 Junk Yard Wishlist
