Cory, do you have the tension adjusters in the rear fully loose and all the way forward?
YEUUUUUUUP! I do. I even ratcheted the suspension down. I am clueless. I thought it was suppose to fit, "easy swap" everyone says. BS! Ok vent over. Now on to buisness. Any Ideas? I read an article about a guy with the same issues but he ended up with the wrong measurements. Mine are front bolt to rear bolt = 23" and both are 5-1/4" down from the top of the tunnel.
Your track is fine unless you got a suspension for a longer track but I am sure your guy knew to sell you a 121" suspension. Are the track tensioners all the in? You will probably need to use a ratchet strap and manually compress the rear shock. Sure wish I were there. It would be a lot easier than trying to help over the net.
