another 4x4 conversion
Old Oct 27, 2002 | 07:40 PM
RBrendel's Avatar
RBrendel
i have a 94 f150 with a 351, the 4x4 conversion looks like it would be fun to do. i dont think i would have a problem with the push button engage, would the setup be easier to find? would it be easier to install? i could go with the manual shifter and manual hubs but i dont go offroading that often, so im not relying on it too much. i understand the hole in the floor for the shifter is already cut out or is easy to cut out? i also understand the driveshaft has to be shortened. will my transmission be able to be modified or will i have to get a new one? if someone could please just tell me a good setup that would be great.
Old Oct 27, 2002 | 08:52 PM
PATS2002's Avatar
PATS2002
Old Oct 27, 2002 | 09:27 PM
MustangGT221's Avatar
MustangGT221
Get an 80-96 TTB, however the 87 and lower use different way of mounting the brake calipers, if you get the TTB from hub to hub you'll be fine. Make sure you get the 4x4 radius arms too. You'll need to move your crossmember, get a driveshaft from a truck that is 4x4 with the same length configuration that you have. The 4x4s use only a 1 piece driveshaft, yours uses 2 i believe. You will need to have the tailshaft on the tranny changed to allow the Transfer case to be bolted up. The plate for the 4x4 shifter is there, just siliconed in so pop that out. Get one with a manual shifter, much easier to install and a much better method overall. There is a post going in one of these forums, i think the 4x4 forum, about auto hubs and the elec. 4x4. Get manual shifted and manual hubs (the hubs are easy to change if their auto). Get a bw 13-56 transfer case. There are a lot of posts on this. If you have any question, feel free to e-mail me.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Oct 27, 2002 | 09:48 PM
RBrendel's Avatar
RBrendel
[updated:LAST EDITED ON 27-Oct-02 AT 10:57 PM (EST)]i read all i could find, even your thread about it, i have the background on it but one thing i couldn't find is if i could use my e40d in the 4x4 setup. *im going to email you.
