Spitting/backfiring
Old Jan 30, 2012 | 03:54 PM
law2212's Avatar
law2212
Spitting/backfiring
Hey everyone, i recently replaced the old 2barrel carb on my 1978 f100 302 v8 with a 4 barrel intake and a holley 650cfm 4barrel carb, now that i have it all back togother when i try to start the truck it wont run and occasionally will spit smoke and fuel out of the carb and sometimes flame. i have tried adjusting the fuel and air mixture and advancing and slowing the timing but cant seem to figure it out. any advice would be helpful.
Old Jan 30, 2012 | 04:13 PM
79F150400M's Avatar
79F150400M
Double check your firing order. 1-5-4-2-6-3-7-8. Check for vacuum leaks and worst case scenario you have an issue with the valves. How did it run before the swap???
Old Jan 30, 2012 | 04:27 PM
77393's Avatar
77393
+1
If it was running good when you pulled the old one off, you prob. have the firing order wrong or you stabbed the dizzy wrong. Were you at #1 on the COMPRESSION stroke when you put it in? If its acting like that when you are trying to start it, the timing is off. Check the firing order in a counter clockwise rotation of the rotor.
Old Jan 30, 2012 | 04:56 PM
OldStyle's Avatar
OldStyle
Rusty Roller
It's real easy to get the order wrong.... We have all done it...
Old Jan 30, 2012 | 05:23 PM
77393's Avatar
77393
If you are sure you have it right and it still won't run, try the HO firing order, maybe somebody changed the cam. How long have you had the truck?
1-3-7-2-6-5-4-8
Dalton Hampton
Dec 5, 2019 09:25 PM
crazyfish1313
23
Aug 3, 2006 07:19 PM
bspeedy
Jun 29, 2004 07:47 PM
moiamiervous
Apr 25, 2004 11:42 AM
project_beast
Nov 8, 2003 11:49 PM
