Throttle Valve???????
Old Apr 21, 2003 | 05:48 PM
scooter_1968's Avatar
scooter_1968
Question Throttle Valve???????
How do you calbrate the throttle Valvue on a
1993 F150
5. 0
tranny = AOD
thanks. scott
Old Apr 21, 2003 | 08:51 PM
PigFarmer's Avatar
PigFarmer
If you're talking about the throttle body/buttertflies then there is no calibration. The idle air control provides the air needed at idle and this is controlled by the computer.
Randy
Old Apr 21, 2003 | 08:59 PM
scooter_1968
Randy thanks for the reply.
heres the problem.
I rebuilt the tranny(AOD) this past saturday. well not knowing any better I didnt use a solvent (brake cleaner) to clean each part. I drove fine. everything was put back together I ran through the gears when I was coming back up to park I went from neutral to reverse and it "SLAMED into reverse the whole rear end shoock. second problem happend today. coming home from work I was going about 40mph and the rmps just shot up to like 5000 rpms it seemed llike it didnt want to change gears.
any hints or clues where to look for the problem..?
I'm going to order a Ford service manual tomorrow...ffrom the local ford dealer..
scott
