Pulling the engine soon, guna need some help!
Old Jan 29, 2012 | 07:56 PM
frdf250's Avatar
frdf250
well guys heres the deal...
i know i have a leak in my rear main seal...couple drips every time i check where i park at the end of the week. figured while im in there i will do a oil pan just for good measure..and then of course with that i figured i would do uppipes. i have a sickness of preventive maintenance right now. while the motors out i plan to clean the engine compartment, put in some sound deading in the firewall and go on a wire tie spree.
im just looking for help weather it be at RRE this year or some other g2g coming up. any takers?
Old Jan 29, 2012 | 09:24 PM
BigAlsPSD's Avatar
BigAlsPSD
If it end up being at RRE I'll be there to help you Phil. Otherwise, not too many plans to make it to the northeast before then.
Old Jan 29, 2012 | 09:25 PM
frdf250's Avatar
frdf250
thanks alan! can you think of anything else to do while im that deep?
Old Jan 29, 2012 | 09:39 PM
BigAlsPSD's Avatar
BigAlsPSD
Rebuild the oil cooler, since it will be easier, other than what you listed, everything else is easy enough to do installed.
Old Jan 29, 2012 | 09:40 PM
tdpower's Avatar
tdpower
Do you have oil in the valley? Rear main leaks are not very common.
Old Jan 29, 2012 | 09:47 PM
frdf250's Avatar
frdf250
thought that too grant...looked in the valley and its pretty clean. not enough to expect otherwise. the bottom where it would be leaking from the rear main seal is COVERED in oil. im going to do the EBPV rebuild to be sure but at any rate i think i want to pull it to do an oil pan.
Old Jan 29, 2012 | 09:55 PM
tdpower's Avatar
tdpower
I think they should outlaw salt.. How is your Dad doing?
Old Jan 29, 2012 | 10:02 PM
frdf250's Avatar
frdf250
ill have to second that. and that brine stuff. just destroys stuff. im not sure if mine is bad but i did scrape some loose stuff off and por15 it. hard to tell if its anywhere i cant see. Unfortunately my dad passed away a couple months ago. mom had to sell the farm and moved herself into a small town house. lots of changes around here. thanks for remembering and asking though man, serisouly it means a lot.
Old Jan 29, 2012 | 10:13 PM
tdpower's Avatar
tdpower
Sorry to hear about your Dad. My parents are still around but have lost all my Grandparents. Hang in there. It's always hard to loose a loved one. Hopefully we will all meet up again..
Old Jan 29, 2012 | 11:09 PM
frdf250's Avatar
frdf250
absolutly! i cant agree more...
...but grant what else do you think i should do while im in there besides listed above anythign else?
Old Jan 30, 2012 | 05:05 AM
megawatt00's Avatar
megawatt00
Bigger injectors, forged rods, girdle.......... lots of things you can do brother.......
Old Jan 30, 2012 | 06:08 AM
bobbyrjw's Avatar
bobbyrjw
Welded cooling jets that Clay is selling.
Old Jan 30, 2012 | 09:12 AM
frdf250's Avatar
frdf250
lol @ jim..i need to start saving.
cooling jets are now added to the list!
Old Jan 30, 2012 | 09:19 AM
joeyd61's Avatar
joeyd61
x2........
seriously, while it is out,how about replacing all the o-rings on the motor
Old Jan 30, 2012 | 09:21 AM
frdf250's Avatar
frdf250
does bob have a kit for that joey? or are you just saying like HPOP, turbo, injectors (probably going to be new if i have money) etc....that stuff?
