Exhaust Question
Old Jan 29, 2012 | 02:52 PM
GSullivan's Avatar
GSullivan
Exhaust Question
Time for an exhaust system on my Super-Duty F-350 Powerstoke. It's a 2001,7.3,DRW dump truck. My question is,should I go with an aftermarket,turbo-back system? Or stick with a stock type system with a muffler. The truck has 87,000 miles and is a great truck for me. I plan on having it for a long time and I take very good care of it.Any info would be great. Thanks,George
Old Jan 29, 2012 | 02:54 PM
BigSilly86's Avatar
BigSilly86
Like A Boss!
Is your truck used commercially? The reason I ask is because Some states test commercial trucks more stringently (I.E.smog, Dot).
Old Jan 29, 2012 | 02:59 PM
GSullivan's Avatar
GSullivan
No, I use it privately to pull my stump grinder and to haul firewood.
Old Jan 29, 2012 | 03:04 PM
BigSilly86's Avatar
BigSilly86
Like A Boss!
Then definitely go the aftermarket turbo back, I would go straight pipe from the turbo. You will notice a performance increase without the CAT and muffler. Plus to buy the stock system will probably be the more expensive route.
Old Jan 29, 2012 | 03:07 PM
GSullivan's Avatar
GSullivan
I wonder if a shop such as Meineke,or Midas could fabricate such a system? Or go to a custom shop?
Old Jan 29, 2012 | 03:10 PM
BigSilly86's Avatar
BigSilly86
Like A Boss!
Usually Meineke is kinda expensive but they should put anything you want on the truck, The last time i got straight pipes i just went to a Mom and Pop (custom) muffler shop and they did it for cheap, It really depends what you want.
Old Jan 29, 2012 | 03:14 PM
GSullivan's Avatar
GSullivan
Did you go with a 4" or a 5"?
BigSilly86's Avatar
BigSilly86
Like A Boss!
Also to warn you straight pipes are kinda loud on a 7.3L, but as long as you go all the way to the rear with it the noise level in the cab wont increase much. Custom muffler shops can put mufflers on your truck if your worried about too much noise.
Old Jan 29, 2012 | 03:17 PM
BigSilly86's Avatar
BigSilly86
Like A Boss!
4" will be good enough ( usually the bigger the better but 4" is all you need) the bigger the pipe the less your back pressure will be.
Old Jan 29, 2012 | 03:19 PM
GSullivan's Avatar
GSullivan
Thanks for the info. It's a great start.I'll start searching tomorrow for a custom shop locally that can fab that up for me.
Old Jan 29, 2012 | 03:23 PM
BigSilly86's Avatar
BigSilly86
Like A Boss!
They can also weld custom tips on your exhaust so if you have a 4" system but you like the look of a 6" out pipe they can weld a shiny chrome tip on it for you, but chrome tips are hard as hell to keep clean for us folks that USE our diesels lol
Old Feb 10, 2012 | 02:33 PM
BigSilly86's Avatar
BigSilly86
Like A Boss!
just curious what route you took with your exhaust?
Old Feb 10, 2012 | 03:41 PM
FordGuy85's Avatar
FordGuy85
Maybe should get a stainless exhaust if you are planning on keeping the truck for ever.
Old Feb 10, 2012 | 03:53 PM
GSullivan's Avatar
GSullivan
Talking
I think I'm going with an MBRP 4" system from the turbo back with no muffler. I will wait til the weather breaks sometime in April to do the job.
Old Feb 10, 2012 | 04:05 PM
BigSilly86's Avatar
BigSilly86
Like A Boss!
sounds good I think you will be happy with that, Will def sound awesome
