fuses
Old Jan 29, 2012 | 11:06 AM
72RichB's Avatar
72RichB
fuses
found the fuse panel under dash, what a nightmare 1 fuse has had new wire soldered to the outside!! & 2 fuses the glass is broken but wire intact but not sure if working properly.
What I need to know is what amp are the fuses meant to be?? fordifiacation wire diagram says 2 2A, a 30A, a 14A & a 15A the 2 with broken glass I took out were 15A, the problem I have is they are different lengths!!! I can't find anything online in UK or USA, anyone help me with part numbers, fuse lengths, where I might be able to get them, how do I tell what posistion they come out of as even with a flashlight I can't read the writing on the fuse panel, my truck is now dead till further notice wrapping fuse wire round the fuse holder is not an option!!
Thanks guys, really appreciate all the help I've been getting.
Old Jan 29, 2012 | 04:56 PM
70-360fe's Avatar
70-360fe
http://www.fordification.com/tech/im.../fusepanel.jpg
Seems to be some conflict, if you check the masters dtagram you can find fuse box with ratings.Hope this helps.
Ford Truck Technical Drawings and Schematics - Section H - Wiring Diagrams
Leemakesmepee
Nov 24, 2012 04:44 PM
materthegreater
Mar 16, 2012 09:05 AM
Danny Stroup
Electrical Systems/Wiring
Feb 3, 2010 06:16 PM
BLACK350/6.0L
May 12, 2005 11:16 PM
Kasilof Ron
Sep 10, 2004 10:01 AM
