Sponsored by: Real Truck
Hub O Rings
Old Jan 28, 2012 | 01:02 PM
MauleOne's Avatar
MauleOne
Hub O Rings
I need to pull my front hubs to be able to replace front axle seals on my E99 F350 PSD.
Are these o rings and seals available anywhere besides the dealers?
Old Jan 28, 2012 | 01:21 PM
dchamberlain's Avatar
dchamberlain
Dorman's web page, and Amazon's, says this kit will fit a 2004, but not a 1999. Thing is, as far as I know, 99-04 hubs were the same. So I don't know why this kit wouldn't fit your 99.
http://www.amazon.com/Dorman-81060-4...pe=6&carId=003
Note that in this kit, and in the one you get from Ford, you get two outer o-rings, but you only need one. You only need two kits if you get into the inner yellow o-ring. As far as I know.
There is a good writeup on servicing the hubs and needle bearings here, which includes what parts you need.
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
The second link above has a link to another source of o-rings also.
Old Jan 28, 2012 | 03:55 PM
MauleOne's Avatar
MauleOne
Thanks for the info
Old Feb 7, 2012 | 08:34 PM
MauleOne's Avatar
MauleOne
Axle Seals
I got the front hubs off and found things to be dirty, wet and rusty.
My hubs feel ok but I am thinking they might need replaced. They have 190K miles on them.
I wonder if I just lub the wheel bearing through the anti skid hole and repack the axle bearing they will be ok?
Erikk
Aug 10, 2010 06:11 PM
t-loc1
Apr 17, 2009 08:17 PM
camsamjam
Feb 12, 2007 07:37 AM
marshall99f150
Aug 7, 2006 07:47 PM
