carb &cable
Old Jan 28, 2012 | 12:09 AM
big mark's Avatar
big mark
carb &cable
question ihave390 ibought a edelbrock carb fordo i need new throttle cable &bracket or linkage parts?
Old Jan 28, 2012 | 08:17 AM
huckdeuceman's Avatar
huckdeuceman
I put a ''Lokar'' throttle cable and carb bracket on my 65'' works great! but if you want original, should be able to get new?
Old Jan 28, 2012 | 08:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5TZ-9A758-AH .. Accelerator Cable-20.00" long / Reproduced
Applications: 1965/66 F100/250 352 2WD (no 390's until 1968 in F100/350's-2WD only).
Old Jan 28, 2012 | 06:36 PM
bunchoftrucks's Avatar
bunchoftrucks
Edelbrock has a stud available for that. I used on my 66. It should be available where ever you got your carb or if you need to order it Summit, Jegs etc. Stud and nut go onto the carb and the cable end snaps on.
Old Jan 28, 2012 | 08:01 PM
camperspecial65's Avatar
camperspecial65
I also have several original throttle cables as well as the original cable retaining brackets for the OE intake.
- cs65
Old Feb 12, 2012 | 11:33 AM
limpysmalls's Avatar
limpysmalls
Which Lokar cable kit did you use? Just put a Holley 4 barrel on my 352 and I do not like the angle on the throttle cable or the pedal feel now. Was looking at the Lokar site but was not sure which to get.
Old Feb 12, 2012 | 02:00 PM
bunchoftrucks
Call their tech line, they are very knowledgable and helpful. When I had a problem they walked me thru it and even called me back the next day to check if everything turned out right. In other words excellent people.
jasindude1
Apr 20, 2016 07:24 PM
wyckedcombo17
Offroad & 4x4
39
Sep 2, 2013 04:53 PM
taylorjgreen
Feb 23, 2012 07:00 PM
gottahaveaford
Apr 29, 2010 04:09 AM
larry derouin
Aug 10, 2001 04:38 PM
