have I just made a 11K mistake?
I just purchased 2000 F350 DRW Super Duty 7.3 with a 4R100. I must say that I am not impressed with this transmission and was looking for a ZF6 but just could not find a reasonable milage truck. The mpg seems poor compared to my 7.3 IDI in a '92 F250 at about 13 highway. the truck is very clean and otherwise nice but 13? I want to blame the 4R100 as I have avoided auto trans in all vehicles over the last 4 decades. It has a Banks turbo. Any thoughts?
My 2000 250 with the same 7.3 and 4r100 is currently getting about 13 most of the time. If I put a really big load on it, it will drop to 10, maybe 11. If I am willing to drive it 45 mph for extended periods, I can see 20+ mpg. I was forced to do that coming across a couple of states years ago during an ice storm. Normal trip that took 6 hours, was 13 hours that day. You're right in line with what a heavy working vehicle will get. There's nothing wrong with the 4r100. It's a good tranny that can take a huge chit load of abuse. Mine's had 375k miles of pretty hard running and is still working fine. Yes, I've changed the fluid and I recently had to go in and tighten the 3 feed bolts are loosening up on all the 4r100's. I've got no complaints with it and it doesn't own me a single penny. it can blow up on the way home tonight. I'll rebuild it next week and keep driving it.
No way, my dad has a 2000 7.3 crew cab short bed with leer brewing addition cap. 3.73 gears with 2 inch level leaf springs and 285/75r16 mickey Thompson MTZ tires and he gets a steady 16.5 mpg around town driving. If he highways a lot the truck easily gets 20mpg maybe a tad more and that's with 230k on he motor. All done by him
Start off with a new Motorcraft fuel filter, check/replace the exhaust back pressure sensor and clean the tube out. Also make sure the air filter is clean and not one of the junk k&n types. Make sure all the intercooler boots are tight and not leaking, also check the turbo impeller for signs of wear or damage. Just becasue a truck is "clean" doesnt mean it was taken care of properly or beat to death then put out dry
almost forgot make sure the parking brake isnt dragging or the calipers aren't sticking. Check front unit bearings also
7.3 duallys have a 4.10 or sometimes a 3.73 gear ratio I believe. My 1999 f250 7.3, extended cab short bed, 4x4 with 3.73 gears and a 4r100, leveled on 305/70/16 (about a 33x12 tire) gets 15-15.5 in town, and 19-20 on the highway. Although that's hand calculated and I haven't accounted for trip odometer error due to the bigger tires. So it's actually probably a little better than what I get. Depends how cold it is outside too. If the EBPV is kickin, that'll suck more fuel than when it's not kickin. And after 3.5 years of driving mine, I've noticed that I get a tad better mpg when it's warmer out.
Ok, you haven’t provided any real information, 2x4 or 4x4, CC, LB mileages, gears, elevation, air intake, mods, turbo size, tire size, lift or stock height etc?? Did you really buy the truck for MPG’s? I have (see signature) 99 f350 Dually, 2x4, CC, LB had 3.73 went to 4.10’s, live at 6500’ and drive/tow up to 13,000’ in elevation. Before the re-gearing I saw 22mph at highway speeds, unloaded at 6500’ give or take several hundred feet, now I see 20ish. I didn’t buy a 9000lb truck for mpg’s, I bought it to tow and do it extremely well…and that’s what it does extremely well. The 4r100 with a 6.0l cooler is a stout transmission, when rebuilt with a upgraded TC and a shift kit it’s a beast.
In the future post post up in the 99-03 7.3L forum. We know our trucks better than most here.
wdsloot2
39
05-28-2020 02:26 AM
