pressurizing fuel system
Old Jan 26, 2012 | 04:18 PM
srqdiesel chef's Avatar
srqdiesel chef
probably a pretty cockamamie idea, but if I have an air leak I can't find, can I hook the schrader valve up to my compressor and pressurize the whole system and then try to find the leak with the old soapy water trick?
Old Jan 26, 2012 | 04:46 PM
turtlemann14's Avatar
turtlemann14
WAY TO MUCH PRESSURE. now that we've got that out of the way, i would put no more than 5-15 psi though the system
it's more than likely in the fuel returns caps or the pick up tube
Old Jan 26, 2012 | 05:17 PM
tjc transport's Avatar
tjc transport
i ain't rite
agreed. since the fuel pump pressure is only 7 lbs, i would not pressurize over 5 lbs.
Old Jan 27, 2012 | 08:39 AM
srqdiesel chef
told you it was a goofy idea, I don't have a leak...right now, but that just popped into one of the empty spaces between my ears
Old Jan 27, 2012 | 10:02 AM
tjc transport
i ain't rite
ain't that goofy of an idear.
i have often thought of pressurizing the tank to help the fuel pump when my trucks suffer from air infiltration.
but they never do it near an air source.
Old Jan 27, 2012 | 12:25 PM
artfd's Avatar
artfd
Exclamation
Some have installed electric fuel pumps and removed the mechanical fuel pumps to get around this issue. The electric pumps generally will prime (or come close to priming) the system rapidly, even without cranking the engine. Turning on the ignition key will start an electric pump.
twom7
Nov 5, 2014 05:04 AM
byo71
1983 - 2012 Ranger & B-Series
Feb 4, 2011 03:40 PM
v8xploder
Apr 18, 2009 12:19 AM
FORDSDOWNER
Oct 25, 2007 08:05 PM
mr_s_edwards
Aerostar
Mar 4, 2001 09:23 AM
