EXHAUST FLUID FAULT
#78
racing1320,
I hope your luck is better than mine. One of the times when I was at the dealer for a DEF fault, the service writer said I should be glad the a tree didn't fall on my truck due to heavy winds on our area. I told I wished a tree would have fallen on my truck so I could get rid of it. That is how frustrated I have been with my truck.
#79
racing1320,
#80
#81
I am new to the fte forum so I really dont know what the protocol is but i feel like i need to raise this as tactfully as i can. This thread was a very informative thread on issues we are all encountering with diesel exhaust faults. It has now become a discussion on a new truck, air bags etc. Please dont take offense but this diminishes the value and retreivability of the def info. Can a moderator help me understand what proper protocol is?
Thanks
Thanks
Sorry Drillbit,
You're right. Didn't mean to hijack the thread.
#82
Here is a picture of it at the dealer, it was raining today so I did not drive it or load my junk from the 04 in it today.
I will take a picture tomorrow, will be sunny.
Window sticker
http://m.ford.com/windowsticker/?u=5...8W4DT5CEB76580
One thing I did notice which made me ask the salesman, When I stepped on it the boost gauge only went to 2 psi. Or is the (4) I see is for 40psi, and the 2 is actually 20psi. Is this because I was towing a load? My 04 would go up past 2 psi. I have a Bully Dog monitor to plug into the port to monitor everything. I will try that tomorrow. I would think 2psi, the truck would not move. I was a little baffled, if the truck has 800lbs of torque - where was it? LOL When I laid into it, I was not impressed with the power. I was thinking I was going to be thrown back. The bucket seats are like sitting your living room compared to my 2004.
Window sticker
#83
I also order a Cold air kit and the Edge Evo. I have the Bully Dog monitor for the 2004. I guess anything will be better then the 6.0.
If my trailer is 16,500 and the truck can handle 20,000lb+, I am not worried. I will have the hitch installed Monday to see how the rear suspension will handle the weight. I hope I will need air bags.
#84
#85
Just adding to the wealth of knowledge:
I received this Exhaust Fluid System Failure message on my 2012 F250 3 days ago. My 250 is five weeks old with 1,700 miles. Build date was around February 15, 2012 (ordered truck on Jan 28<SUP>th</SUP>, 2012). Onboard vehicle report states DEF Fluid is OK and I have not gotten any DEF warning messages pertaining to low DEF volume. This morning I had to drive my kids to school with my 7.3 2003 Excursion as I left the $55,000 new F250 in the driveway. Not happy. <O</O
<O</O
Called the service manager this afternoon and explained the problem. His reply was “Oh Lordy”. Too funny. Hope it’s not a big problem. They gave me a car rental. <O</O
<O</O
Picked up my truck the next day and they did a FLASH of the PCM and TCM following a TSB 12-3-5 (Reprog PCM-REDUCT DOSING). Have driven only 125 miles so far but things look good. Interesting, my on board fuel calculator is reading in the 19 mpg range. Since new it’s usually in the 16 – 17 mpg (this is not hand calculated). I wonder if the reflash changed its fuel efficiency a bit (?).<O</O
Brian
<O</O
<O</O
Brian
#87
DEF warning
I have had my 2012 F350 for 3 weeks, this morning I got my first DEF warning that I have 50 miles to go until the truck will only do 50MPH. The truck has 925 miles on, the fluid level in the DEF tank according to the electronic display is ok. Ran the system check and it also showed the DEF warning. Ran the vehicle health report and sent to the sync my ride at ford and the report also showed A DEF system fault and said the fluid was contaminated and the vehicle needs to be brought in for service. After starting and stopping the truck a couple times the warning went away? I went and purchased some DEF fluid anyway as we had a about 100 mile drive to get home and thought it might help in case that warning came up again. I guess I will take it in for the dealer to have a look at, any input would be appreciated. I just got rid of my F350 with the 6.0 liter diesel and was hoping I would have better luck with this truck.
#90
