EXHAUST FLUID FAULT
#61
Here is a picture of it at the dealer, it was raining today so I did not drive it or load my junk from the 04 in it today.
I will take a picture tomorrow, will be sunny.
Window sticker
http://m.ford.com/windowsticker/?u=5...8W4DT5CEB76580
One thing I did notice which made me ask the salesman, When I stepped on it the boost gauge only went to 2 psi. Is this because I was towing a load? My 04 would go up past 2 psi. I have a Bully Dog monitor to plug into the port to monitor everything. I will try that tomorrow. I was a little baffled, if the truck has 800lbs of torque - where was it? LOL When I laid into it, I was not impressed with the power. I was thinking I was going to be thrown back. The bucket seats are like sitting your living room compared to my 2004.
Window sticker
Nice! I love my 1 ton dually.
There is a report of cycling the key seems to wake up the turbo. Perhaps she was still sleepin' when you drove er. Something doesn't sound right. I still love runnun' thru the gears on this thing. Two-thirds to three-quarters throttle seems to bring a bigger smile than full throttle. Don't know why.
Congrats again. BTW, what do you tow?
#62
When I test drove the truck, the CEL was on. When I went to leave it was off. They said I could come in anytime to check it out.
I have a scanner, so I will check it out before the dealer has there hands in there. I have a feeling the dealer will never tell you the truth if it is something bad. LOL
#63
I tried different throttle positions and I was still not impressed. I am towing a 16,500 goose neck trailer with living quarters.
Well, hells bells. I hope you find out what's going on.
Only one time was I disappointed while towing my 5er. I was climbing Strawberry Hill, south of Deadwood, SD. Weighing in about 18k going up a 8% grade at about 50 mph. I didn't like the putzzy feeling so I mashed the throttle and it wouldn't even downshift. Just sat there and blubbered it's way up the hill. I was too freaked out trying to figure out what was going on, I should have downshifted it in manual mode. I'm thinking it was maybe in regen. Hard to tell with this thing unless you catch a whif of the exhaust or see the message on the screen.
#65
Thanks
#66
#67
Yepr, all stock. I love hookin up the 5er and draggin it somewhere. The stability of the DRW is amazing. Really boosts your towing confidence. The power is awesome in my opinion. I traded in an 07 3/4 ton Crew cab Dury diesel I used to pull this same 5er and as far as power, I don't feel like I gave up anything. The Allison tranny was a lot smoooother shifting tho.
My two biggest complaints are the erratic tranny patterns and the shudder in the rear end when I have the 5er behind me. Dealer already put in a new third member, as per FOMOCO. That didn't help a bit. Will probably add a set of air bags eventually.
Mine is a job1, June 2010 build date. I bought it in Aug, 2010 and only have 18200 miles on it. I don't daily drive it much. Average about 1000 miles a month. Of that 18000, approx. 10000 of it is with a trailer behind it.
#68
#69
I am new to the fte forum so I really dont know what the protocol is but i feel like i need to raise this as tactfully as i can. This thread was a very informative thread on issues we are all encountering with diesel exhaust faults. It has now become a discussion on a new truck, air bags etc. Please dont take offense but this diminishes the value and retreivability of the def info. Can a moderator help me understand what proper protocol is?
Thanks
Thanks
#70
No problem, how many posts were on here about my truck and air bags? As I am numerous forums and never had anyone bring this up about getting off topic. Not like we are talking about cooking food. I have left forums due to peoe that make comments like this. I have many things to say about a person like this but I will not open up a can of worms. Asking for a moderator to get involved means you could not leave a message first but had to ask for a moderator. This tells a lot about a person.
#71
#72
My point about me buying the truck is related to this thread. The DEF problem/issue did not discourage me from buying the truck. I felt that would be helpful to others that maybe constipating this as the deciding factor. Then after my statement that I did make the purchase, someone suggested that I post a picture to confirm the purchase. We would not want any fake/phonies on here. I also had the link for the window sticker on the thread.
I think calling the principal before attempting to suggest to those involved would be my first option.
#73
#74
#75
racing1320,
Best of luck on your new truck!
My truck has been plagued with DEF fault issues. If I had a "do over", I WOULD NOT buy this truck again.
2horses,
I think you are right that the DEF fault issues are with the 2012's. A guy I work with has a 2011 and has had zero problems.
On a side note, my national back ordered parts (NOx module and NOx sensor) showed up and were installed on Tuesday April 10th. Time will tell if these parts fix my truck's DEF fault issues
2horses,
