Adding sensor
Old Jan 25, 2012 | 04:16 PM
JonArmy's Avatar
JonArmy
Adding sensor
Well I'm waiting on my Egde CTS to come in, I just received my coolent filter from www.DieselSite.com, well of course I two in ports and two out ports, well I am going to use the plug to block the second out, I am thinking of getting Edge EAS Pressure Sensor on the second in port, this way I can view the pressure that is coming into my filter assembly.
By what I've read as the filter gets clogged/full it restricts the flow of the by-pass filter (which dosn't affect the main flow). If you don't change the clogged/full filter that the by-pass system itsn't working like it should.
Has anyone used the pressure sensor from Edge and would this be a good use of the sensor?
Sous
39
Jan 9, 2018 05:31 PM
cameeks
Sep 7, 2012 08:28 PM
vfelix702
Jun 30, 2011 12:26 AM
sawtooth
6.4L Power Stroke Diesel
Dec 12, 2010 07:15 AM
ckal704
Jan 27, 2009 06:39 AM
